Question about Microwave Ovens
My Kenmore Ultra Wash Model 15895/15891 is leaking out the door.No water in underneath the bottom.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: My Kenmore ULTRA WASH Dishwasher
Hi
It seems that something is blocked in the drain pump assembly resulting in a dead unit. Pull the bottom front panel out and clean the drain pump assembly, after this it should work, if it does not then the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 20, 2011
Kenmore microwave model 721 loose door
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
Jan 20, 2014 | Kenmore 62702 Microwave Oven
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
While dischwasher is running, water are leaking from the front.
Depending on the model, there are corner seals (kenmore are black) at the base of the door these can fail , Frigidaire, Galax, and Whirlpool/ Tappan use small plastic diverters that are semi clear.
If these are missing in the corners nearest the base of the door then this problem
will occur. Also if you are using regular dish detergent, it will oversuds. One last note,
if the dishwasher has not been used for a while due to handwashing on the disposal side
of the sink, the soap will make its way into the sump of the dishwasher and cause this
condition. Try using several pitchers of water and pumping out the water by rotating the
control knob till it pumps out to dilute the soap. Hope this helps.
Jul 17, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
My coffee pot on a kenmore brew and wave is missing a stop
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
Jun 27, 2009 | Kenmore Microwave Ovens
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore Microwave door adjustment
Depends on the door. It likely can be adjusted they have 2 screws on the door bracket you may have to remove the cover to see them. But it also needs to be checked with a leakage meter to make sure its not leaking.
RadioShack used to make a low cost meter not certified or anything but a good way to see if its leaking.
Jan 08, 2009 | Kenmore 62622 Microwave Oven
Turntable won't turn anymore
The turntable has a drive motor which is located behind the panel that covers the BOTTOM of the oven. It could be that this small drive motor has failed. Replacing it should be simple and doesn't cost much. If the oven is mounted, you can leave it in place in most cases and just remove the bottom panel. Make sure the unit is UNPLUGGED before servicing, however. Please post back with your complete model number (located around the door opening) so I can be sure. I'm having a hard time locating any parts info and want to make sure I give you the right advice.
Mar 31, 2008 | Kenmore 64282 Convection/Microwave Oven
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore microhood model 665.62612200
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
It's also possible there may be a problem on the circuit board, which we repair nationwide.
Oct 22, 2007 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
