Question about Philips Vacuums
I have a philips marathon fc 9202 vacuum cleaner. it has worked fine for a number of years but suddenly has no power. what can i check to diagnose the problem?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I finally found the root cause - Applies for FC9225, but may also solve other types of the same family.
The problem is the switch for the dustbox (not sure if the hinge is worn or the sensor (contactless switch) has another issue). Removing this safety switch (allowing you to switch on the vacuum cleaner without dustbox and filter cartridge properly installed, which I judge not a major 'risk'), permanently solved the issue, 1. Remove the lid 2. Remove the big sealing ring on the bottom of the lid 3. Pull the cantilever switch out (and dispose ;-) ) 4. Re-assemble 5. Fixed the problem in my case
(check 4 last images I added)
For your entertainment: I also filled the connector at lid side with glue gun glue, de-soldered all capacitors and measured them, completely dismantled the motor, pulled the brushes and cleaned the commutator... to find it was just the ****** switch...
We had similar issues (all power level lights start flashing when connecting). We could extend lifetime by electric contact spray. But also this stopped working at some point. Today I finally dismantled. Tip 1: to remove the lid, just push the 2 plastic covers outward at the hinge (no need to dismantle the lid) and push out the shaft.Tip 2: when dismantling main body, unscrew the small wheel below the 'dirt box' (OPPOSITE DIRECTION = CLOCKWISE TO LOOSEN). Tip 3: only dismantle the main plastic cover by loosening all screws.
Then dismantle the main body connector, remove the rubber block at the backside of the connector, make sure the 4 wires are as deep as possible in the connector, fill the connector with glue gun and put a tie rap to keep 4 wires together.
If you want to dismantle the connector, you need to push inside the 4 small latches near each wire, BE CAREFUL NOT TO ROTATE THE INNER OF THE CONNECTOR 180DEG WHEN RE-ASSEMBLING (there is no poko-yoko to avoid this).
I added some pictures to hopefully make things a bit more clear.
I have a philips marathon - philips-marathon-h220o22wl0102llkt345joym-3-0.jpg
Posted on Oct 02, 2016
Hi there my name is glen from dublin ireland....
i cant solve your problem but can explain what is happening...
i've had 3 phillips marathon vacuums over the last 5-6 years and are by far the best vacuum on the market..
but over time the constant pulling and re-coiling of the flex is loosening the wires from their connectors deep inside the unit ...
its the only explaination i can think of ,as i've changed the fuse , the plug and shortened the flex and re attached the plug but to no avail..hope this helps, just buy a new one they're brilliant
Posted on Jan 08, 2011
Why did it lose power during use
Worn brushs in electric motor, it is comon in
units used much, maybe a bad or burnt switch
Jun 01, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
My electrolux oxygen vacuum cleaner shut off and will not turn back on. It's less than a year old, but I bought it off Craig's list--they were the orginal owner and they said they bought it in May of 2008....
No..Electrolux is really great about warranty service. They will help you even though you are not the original owner. owners manual. Here is a link to the site. Also, you might check for an obstruction. The Electrrolux is thermostatically protected. Means that if there is no airflow through the motor, the motor will shut down before overheating can occur. Remove your hose from the cleaner. Drop a quarter down through it, did it come through? If not, you have a clogged hose. If it came through, remove your wand from the power nozzle, look througfh the wand, is it clogged? Now, look at the power nozzle, can you see light through the elbow? Your cleaner will come back on after it has cooled. Try the machine. It should be working now. I hope I could help to Fixya! Please let me know if I helped you. Thanks, Rene (the Vacuum Doctor)
Nov 15, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux vacuum cleaner z4703 doesn't start
HI It could be the a number of issues.
The actual power switch could be at fault and needs replaced which has to be done by an official repairer.
OR if the vacuum cut out initially wait for a day and then try it again.
Also if the filters have been cleaned check that there is no dirt stopping the motor from coming on i.e. check the beater bar (remove the hood if neccessary) and check the drive belt is intact, also check all tubes to see there is no clogging.
If you have cleaned the filters you need to make sure they are dry rather than damp to wet as water seeping into a motor is very dangerous.
Jun 27, 2009 | Vacuums
No suction from vacuum.
Blow out the filter with an air compressor if available. this is causing your problem. its usually a foam filter
Mar 26, 2009 | Hoover U5290-900 Upright Vacuum
I have a Kenmore canister vacuum cleaner model 116.23912 that I purchased in 2004. At times the machine works fine, while at other times it will not turn on. I've done a couple of things to try to diagnose...
Since the vacuum is about 13 years old, the on/off switch may have worn out or is wearing out. Go to Sears Online In Store Shopping Appliances Clothing More and you can find parts for your vacuum online. It is a pretty simple replacement part.
Nov 14, 2017 | Vacuums
No power in power nozzle
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below: Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
452 people viewed this question
Top Philips Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
