Franklin Chef FT386 Refrigerator With Ice Box Logo
Posted on Oct 08, 2010
I have the fim350d it has a beeping sound and all the lights are flashing on the control panel. the bucket is full of water but does not make ice. can you help me. [email protected]
My hanseatic dishwasher is beeping and flashing on the little glass symbol and it stopped working.
https://removeandreplace.com/2015/12/21/dishwasher-has-beeping-sounds-blinking-lights-how-to-reset/
Dishwasher lights flashing or blinking. The heating element heats up the water to operating temperature. If the water doesn't reach the proper temperature after a set amount of time, a light on the control panel might start flashing. ... If the drain pump is not working, a light on the control panel might start flashing. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/28---/Dishwasher-Lights-Flashing-Or-Blinking
Flashing lights and or beep sounds can mean the dishwasher problem was from a power surge or power outage. You can unplug the dishwasher from power or shut off the breaker to the dishwasher for 1 minute. This may reset the dishwasher and get it back to working order.
May 12, 2020 • Dishwashers
Model E402b. Why is the alarm going off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Inoperative Ice Maker
FROM WHAT YOU SAYING LG HAS MADE YOU DO A SELF TEST ON THE ICE MAKER AND ITS WORKING FINE.YOU NEED TO CHECK THAT YOUR SECOND WATER VALVE AT THE BACK BOTTOM RIGHT CORNER IS WORKING OK THAT MIGHT BE YOUR PROBLEM.GOODLUCK/ MOHAMED
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Control panel lights up-nothing else happens
first check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
Top Franklin Refrigerators Experts
john h
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Franklin Refrigerator Expert? Answer questions, earn points and help others
