Question about HP 180 Color Copier
What cables or connectors do I need to connect a HP Color Copier 180 to my computer?
  • 81 Answers
You need a Printer USB cable. They come in whatever length you will need.
Posted on Oct 08, 2010
I got the 400ci color kyosera copier. installed the cartridges, waste basket, when i turn on the copier it gave a "c3100" message. please advise.
c3100 is an error associated with the scanner carriage. open your document feeder and check if the carriage cables are OK.
Jun 13, 2011 | Kyocera TASKalfa 180 Copier
I have an hp pavilion dv4 laptop and an hp digital copier 610.I do not have the usb cable.it's gonna work with wireless?
This is a USB unit. If you use a wireless print server (for a USB printer), you may get some of the functions to work wirelessly. You will need a USB cable to do this. However, most print servers do not handle the bi-directional communication for the scanner. (You will be able to print if you have the correct driver installed.)
As far as I know, this printer can't be fitted with the HP Jet Direct module (this is the internal print server for some of the HP printers). However, there are external JetDirect options: http://h10010.www1.hp.com/wwpc/us/en/sm/WF02a/18972-18972-236253.html . Check the specs for each model to see if they are compatible with your printer. (The first wireless one isn't compatible as far as I can tell.)
USB cables are available at most stores. Make sure to get one labeled A/B Male/Male ends. For best results, the printer should be directly connected to the computer (or connected to a powered hub). The cable should not be more than 6' long.
I wish that I could be of more help.
Nov 09, 2010 | HP 610 Color Copier
Ca 20 error on toshiba 3511 copier
CA20 indicates H-Sync detection error.
U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201)
on the LDR board open circuited, broken or disconnected. Try to replace another cable.
Jan 05, 2010 | Toshiba E-Studio 3511 Color Copier
Need printer cable that will hook to USB port
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=381274&CatId=76 this is a cable that will go from parallel to usb I am not sure if this is what you are looking for so check the photo and compare to your printer hook up. I hope this helps
Apr 30, 2009 | Computers & Internet
No cable and no sound on speakers for flat screen monitor
Hello Tothelake45,
When you bought your computer, you might have received lot of cables along with it... so find out the cable that has the jacks on both the ends of the cable. The Jack looks like that shown below.
So we are looking for a cable that has a jack at both the ends.. One jack goes into the soundcard of your computer (the green color coded port or the port where you normally connect your desktop speakers or headphones) and the other end goes to the similar connector on the monitor which is color coded as well (green color).
Please let me know if that works and please do not forget to rate the solution.
Thanks and Regards,
Srinivas
Apr 08, 2009 | HP Pavilion A6430F Desktop PC
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
NEED TO REPLACE dc CONTROLLER ON HP 3700N
Remove the left cover.
2 Disconnect all cable connections (19 connectors for the HP Color LaserJet 3500 series printer and 20 connectors for the HP Color LaserJet 3700 series printer).
3 Remove four screws (1) and remove the PCB (2).
Dec 12, 2008 | HP LaserJet 3700n Printer
Hp 2110 printer
You can get this cable at any computer shop. Just go with your damaged cable and show them.
Apr 23, 2008 | HP PSC 2110 Color Printer
HP 180 Color Copier Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
