I can't gt channels. Also, I press the menu on the remote and all I get is fast lines that I can't stop. What can I do. It for a Trinitron Sony TV..... please help
    Genius:
  • 1,622 Answers
HELLO,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS HELP IN SOLVING THE PROBLEM.....
Posted on Oct 08, 2010
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
I need to set digital channels on my Sony Trinitron system. It will not auto-program on digital on analog. model KD-27FS170
You need to switch the TV to digital mode before you run the auto-program. Press the "DIGITAL/ANALOG" button on your remote before you run the scan. After switching to digital mode please complete the following steps to run the auto-program:
1. Press the "MENU" button on the remote
2. Press the right arrow ">" button on the remote once to highlight "CH" (looks like 3 boxes)
3. Press the "+" button (in the center of the arrow keys) to select.
You will now be in the "Digital Channels" menu. If you are in a menu called "Channel Setup", you are in the wrong mode. You should exit the menu, press the "DIGITAL/ANALOG" button on your remote and start again at step 1.
4. Press the down arrow on the remote to highlight "AUTO PROGRAM"
5. Press the "+" button (in the center of the arrow keys) to select.
The auto program will now run. This could take a while to complete but a progress bar is displayed so you can see how far it has gone.
If you can't get this to work or need further assistance, please post back.
Regards,
BElectric
Dec 09, 2010 | Sony Televison & Video
I have a Sony Trinitron model KV27S35, but no remote. How do I program the tv without the remote?
The SETUP button on the case accesses the menu.
Press Channel +   to select Language.
Press Volume -    - now the tv will be reset to factory condition.
Press Channel + to start the AUTO PROGRAM and wait for it to finish.
Press Channel -  to exit it.
That is all. If you need more then all the menu options can be accessed thru the key on the tv.
Aug 17, 2010 | Zenith ZN110 Remote Control
I have a sony trinitron about 27 to 32 inches. it was left in the house when i moved in so there is no manual and no remote. I bought a universal remote that works but the tv is programed to certain...
Hi, if you have the remote control you go in the menu and you browse to set up and you choose air/ cable
and you set it to air or cable thene you press enter then you look for channel programing and press enter
and you will be don if dont have a remote you have a
menu button on the tv set push on and you browse
with channel up or down and select the option you want with volume + as i describe in the text.
hope that will help
have a nice day
Mar 28, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Can't set up the channels on my TV
Some models require two buttons to be pressed together for menu access - usually at the bottom or side.
Feb 12, 2008 | Sony FD Trinitron KD-36XS955 36" TV
Lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron kv-x2982u - how do I tune a channel in?
I have KV-X2982U, With the television on 4, Grip the top side of remote control RM-833 and reverse it, putting it back in the holder. Press Menu on the remote. Several options appear. Press the white button "Preset". You can then manually tune in the setting to channel 4 by pressing the green button, or alternatively you could tune in all channels automatically by pressing red. You may get a better signal on the other channels this way. Good Luck.
Jan 16, 2008 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
