Question about Hamilton Beach 750BC DrinkMaster Classic Stand Mixer
Just need the wand and have been online searching for over an hour! Can you help?
    Champion:
  • 248 Answers
Try,-appliancefactoryparts.com-or,-smarter.com
Posted on Oct 09, 2010
I am looking for a wiring diagram for Hobart 4822 grinder
Ask direct. not available online.
Electrical Installation; Electrical Connection - Hobart 4822 Installation ...
https://www.manualslib.com > ... > 4822 > Installation and operation manual
  1. Cached
Hobart 4822 Manual Online: Electrical Installation, Electrical Connection. The Electrical Installation Of The Chopper Must Conform To The Local Electricity...
[PDF]4822 MEAT CHOPPER 4822 MEA T CHOPPER - Hobart
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7515.pdf
  1. Cached
  2. Similar
Page 1 of 2. 4822. MEAT CHOPPER. 701 S Ridge Avenue, Troy, OH 45374. 1-888-4HOBART ... CORD AND PLUG: A 6 foot, flexible 3 wire cord is furnished with the ... CAPACITY: 4822 will grind 16 lbs. per minute, first cutting through a 1?8" ...
[PDF]CATALOG OF REPLACEMENT PARTS
www.hobart.co.kr/data_file/4822Aug04.pdf
  1. Similar
4822 CHOPPER REPLACEMENT PARTS. F-43093 (August 2004). © HOBART. Table of Contents. 3. ELECTRICAL UNIT. 5. #22 CHOPPER ATTACHMENT ... wiring diagram for Hobart 4822 grinder Google Search
Feb 08, 2017 | Hobart Food Mixers
Where can I order a whip head for my Dr tech
if you perform an online web search through a search engine such as google or bing etc, putting in the make model and the word "spares" then several vendors should be thrown up from which you can order the required item
Nov 05, 2015 | Food Mixers
The power head nose that the mixing paddle snaps into fell off the mixer exposing the nose gear and ring gear inside the head. There is no apparent locking mechanism to hold the plate in place to the...
Hi BOBLUCAS820. From the symptoms you describe, I believe it is your Planetary/Agitator Shaft assembly that has fallen from the ‘head’ of your mixer. More than likely, the retaining pin or clip which secures the Agitator Shaft assembly to the Planetary has ‘sheared’ or broken, allowing the whole assembly to ‘fall’ out of the mixer head.
The good news is that this can be fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, feel adventurous, and your mixer is not under warranty. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB), of the 24 listed under Parts List (24) (check to see it this matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your errant part is Illus No. 18, Retaining pin. There are two shown on page 4, and possibly Illus No. 25, Retaining Clip.
To gain access to these pieces will require removing the Transmission Housing (Illus No. 7), removing all the lubricating grease and removing the Illus No. 21, Bevel Gear. You’ll need a regular or Phillips screw driver, retaining clip pliers, and punch driver. When you remove the grease form the transmission cover and gears, be on the lookout for pieces of the Retaining Clip (Illus No. 25). The pieces of the sheared retaining pin should be found between the Bevel gear and the Worm Follower gear (Illus No. 19). With the transmission disassembled, you should be able to determine what parts need to be replaced and can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 22, 2009 | KitchenAid KP2671 Professional 6 Series...
Our K45SS shaft cracked and beaters will not slide onto the shaft. Is a new shaft available and is it handyman replaceable?
Hi BLRWETLAND_S, from the symptoms you describe, it appears that your Agitator Shaft had cracked and needs to be replaces. The good news is that this can be fixed quite easily (OK, maybe a little effort) by yourself if you are a DITY type person, feel adventurous, and your mixer is not under warranty. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number in your K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 26, Agitator Shaft Assembly, which is what you need to replace.
You can order a replacement assembly and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides the replacement agitator shaft assembly and grease you might consider replacing the gasket and “O”-ring, too.
In order to get to release the agitator shaft from the planetary, you’ll need to remove all the lubricating grease from the gear case housing and from the gears. (This is when the job gets fun…) You’ll need a set of punches to remove the retaining pins and possible retaining ring pliers to get to the agitator shaft. Once removed, you’d reassemble in reverse.
Dec 22, 2009 | KitchenAid K45SS Classic Stand Mixer
Is there a site that shows which way the motor brushes go back in?
Hi, ROSANA73, Yes the brushes need to be installed so that they both seat correctly on the armature's commutator.
Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled ‘Motor And Control Part’. Locate Illus. Nos. 47, Brush Holder, which shows the order the brush assembly is installed.
If a part has broken and needs to be replaced, here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
Dec 21, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Mixer stuck in off position.
Hi BERRIESNW. From the symptoms you describe, it’s likely the Speed Control Assembly Lever has become jammed internally. You should be able to inspect this yourself and determine if that’s happened with just a little effort.
Be sure to have your Parts List Manual on hand, too. If you don’t have the original you can easily download a PDF version from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Turn to pages 6 & 7, titled ‘Motor And Control Part’. Locate Illus. Nos. 1, 2, 3 & 4, Pivot screw, Spring washer, Speed control assembly lever, and Control plate spring, respectively. Carefully inspect these parts to see if they have not come loose, particularly the pivot screw and spring washer. Or quite possibly Illus. No. 5, Speed Link & Cam is jamming against some other mixer component and ‘locking’ your speed control lever. I would concentrate my attention in this area.
Dec 18, 2009 | KitchenAid K45SS Classic Stand Mixer
Oil leak
Hi LORING1. How much oil are we talking about, and over what period? How old is your machine?
Your KA mixer’s internal gears are factory packed with enough grease to last a 'lifetime', whatever that means. Depending on the age of your mixer, where it was stored (warm temps possibly?) and how long it's been idle and/or how heavily it’s been used; these factors all will eventually cause the mixer’s grease base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft. Gravity can be very insidious.
When you say ‘underneath’, do you mean underneath the mixer head, like out of the planetary (agitator) or underneath the pedestal?
If you are DITY type person, and feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download it from the KA website http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW select Parts List (1) and then check to see it this matches your mixer model).
Turn to pages 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. For starters, you should consider reordering the gasket (Illus. No 19) and O-ring (Illus. No 34). Once apart you can check for any other unseemly wear and tear on the gears, etc.
If you really feel the need to re-grease your transmission, you should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should be search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
Dec 15, 2009 | KitchenAid K45SS Classic Stand Mixer
Aristan Open/Close
Hello again LESZCZ2. Sorry for not replying sooner to your clarification. You don’t need to send me photos. I think I now understand what you are describing. Your mixer head ‘locking’ mechanism is not working correctly. Is that correct?
I hope you’ve been able to download your mixer’s Parts List manual. If you haven’t, I suggest downloading a PDF version from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, KSM150 and select one the files listed for your model that appears under Parts List (61): KSM150PSWH0.pdf (773.44 KB) and save that file to your PC.
Turn to pages 5, titled ‘Base and Pedestal Unit’. Locate Illus. Nos. 11, Link & Lever Latch, which includes Illus. Nos. 10, 12, 13, 14, 15, 16, and 17.
You will need to disassemble your mixer head top to inspect this assembly and carefully inspect the latch parts. It is possible that the link (Illus. No. 16) has broken or become unattached from either the latch (Illus. No. 10 or the lever (Illus. No. 17); or possibly the assembly has just become loose and needs to be tightened. A visual inspection will determine what you need to do.
If you find you need to order repair parts, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should be search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping. I don’t know if you’ll be able to find any vendors that carry KA parts in Poland, but you could try online.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Again, it may be difficult to find an appliance repair shop that handles KA where you live in Poland.
I hope this is more helpful than my first solution. Howard, Burke, VA
Dec 13, 2009 | Food Mixers
I have lost the mincer attachment to my wand - almost 25 years old now and still going strong. HOw much to replace and post this part please.
goto:
http://www.google.com/search?hl=en&client=firefox-a&channel=s&rls=org.mozilla%3Aen-US%3Aofficial&hs=L6q&q=bamix+accessories&btnG=Search
and choose products from your favorite vendor.
Nov 08, 2008 | Bamix De Luxe Hand Mixer
Hamilton Beach 750BC DrinkMaster Classic Stand Mixer Logo
47 people viewed this question
Top Hamilton Beach Food Mixers Experts
Andrew Taylor
Andrew Taylor
Ruth summersides
Are you a Hamilton Beach Food Mixer Expert? Answer questions, earn points and help others
