Question about RCA HDLP50W151 50" Rear Projection HDTV
Thanks! thanks for all your help! you are great!! J
  • RCA Master
  • 8,617 Answers
Youre welcome, dont hesitate to ask if you need anymore help. The RCA is a great DLP so I would enjoy helping you get it operating again.
Posted on May 30, 2008
Sega Genesis Model 1, Color is messed Up
"Every Game plays great but displays a Blue or Green Tint or sometimes is just really dark, I have two other Model 1's that work great, I'm looking for a hardware fix. Thanks"
The surrounding capacitors are the culprit here, I believe. They can be replaced and many places exist to help with just this problem.
Apr 24, 2010 | Sega Genesis Console
Tip
Great advice. I was able to replace my dog ears today with your help. Mine was a...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Aug 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Just wanted to thank you for helping me solve my problem. This is a great website!!
I think it is a great website also...and great,fun way for me to help people!!
heatman101
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Need to remove door panel on a pontiac g6 to replace broken door handle?
I found a great write up on your door panel I think will help you out allot Click Here Its a great sight for any G6 owner. If this was helpful please dont forget to rate me.
Thanks and have a great evening
Jun 11, 2009 | 2006 Pontiac G6
No longer have original remote had one that worked now it now longer works what am I doing wrong Thanks for you help
Thanks for getting back to me. Decided just maybe it was in the control itself even though it was a new one. Went out and purchased a different kind and alas it works great.
Thanks again for getting back to me. Have a Great Day :o).
Apr 18, 2009 | Televison & Video
UNLOCK 6288 FROM 3 AUSTRALIA
IMEI: 359551010734019 Security Mastercode: 1726363150
Jul 09, 2008 | Nokia 6288 Cellular Phone
Unlocking a samsung t309
Great these steps worked on my phone and it is Unlocked permanently
Thanks for your help shevng
Nov 27, 2007 | Samsung SGH-T309 Cellular Phone
No instructions
Go to this link armed with the four number module code from the back of the watch; http://world.casio.com/wat/download/en/manual/ Hopefully they will have a user guide for your watch. Hope this helps :)
Mar 09, 2007 | Casio W752V3AV men's watch
RCA HDLP50W151 50" Rear Projection HDTV Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
