Question about Sony KP-51WS500 51" Rear Projection Television
Hi i changed red crt for sony kp51ws500,yoke too,picture both side one inch wider,tell me how get in to service mode to adjust that, i changed both STK,and fuse.auto focus not help. THANKS tom
  • yut7 Oct 09, 2010
    Hi tim
    thanks your tip and mamual,all fixed!
    Thanks
    tom
    President:
  • 2,777 Answers
Yikes, you can get into tv service mode by turning the tv off and pressing "display, 5, volume up and then power. From there though you may want the service manual for the TV which can be found:
http://www.eserviceinfo.com/download.php?fileid=20634
Then go down the page to the part where it says to download click here... has it link for it
Usually it costs money but I found it there for free for you.
Thanks
Tim
Posted on Oct 09, 2010
Service mode
To know more about the service mode entry method, check the site linked here. It has service mode entry, adjust and exit procedure to many model Sony TVs. It is not practical to type in all of it here by this window.
Dec 05, 2013 | Sony FD Trinitron WEGA KV-XR29M80 TV
How can i adjust china tv circuit with 21inch sony crt yoke. Please tell me.
dir tery i use 20 inch monetor crt conact with la76810a tv kit horezantel lin
May 31, 2012 | Televison & Video
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Kp51ws500 color flickering
I'm afraid I don't have good news. This is known as the "Flicker Issue." As a Sony authorized servicer, the shop I worked for was directed to replace all three of the CRT's in the limited number of sets that experienced this issue. The cost per tube is typically around $200. If you decide to take this on, it is best to replace one CRT at a time, power up the set and do the yoke adjustments and electrical alignments to get the new color to line up with the existing ones.
Jun 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Adjust Convergence on Zenith B27A11Z
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Feb 09, 2009 | Zenith B27A11Z 27" TV
Sony 32 inch crt tv
On the neck of the picture tube you will see the large yoke. Loosen the srew slightly and just rotate the yoke assembly very little counterclockwise. That should correct your problem.
Oct 12, 2008 | Televison & Video
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Toshiba 50H81 manual convergence
are you sure it's yoke? these are know for bad convergence amp ic's
other wise it's a screw and glue holding the yoke in place loose the screw and try to break the glue with out breaking the plastic on the yoke, the other thing you can do is adjust the magnets which have tabs on the yoke. i would mark the position's of everything on the tube with a sharpie so you can get it back to start.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 50H81 50" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
600 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
