Pilot light wont stay lit, i was told it may be the fuse, where is the fuse on the lennox g803-105-1??
  • Heating & Co... Master
  • 2,557 Answers
Check out thermocouple if fitted or the flame senser might need cleaning or check connection of senser
Posted on Oct 09, 2010
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
Tip
I have a standing pilot that wont stay lit.
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.<br /> 1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)<br /> 2. Make sure that the tip of the thermocouple is in the pilot light flame.<br /> 3. Make sure that the thermocouple is clean.<br /> <br /> if you have done these and it still doesnt stay lit, buy a new thermocouple.
on Mar 14, 2011 | Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
Lennox G8Q3-90-4 will not ignite the pilot. The
While holding down the control knob for the pilot, you either have to use the pilot ignitor or match light the pilot. Then old the knob in for 60 seconds, before releasing it. If the pilot remains lit, turn the control knob to ON. If the pilot does not remain lit, the Thermocouple or Thermopile may need to be replaced.
Hope this helps you to solve the problem.
Mar 23, 2011 | Heating & Cooling
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Pilot light will stay lit Lennox G8D2-82
You may need to replace the Thermocoupler. It screws into the gas regulator and the sensor end is set in the flame of the pilot light. You can get one at any appliance parts store. The Thermocoupler simply feels the heat of the pilot light and sends a very small amount of voltage to the gas switch that opens when your thermostat calls for heat. If the pilot light isnt lit, no voltage from the sensor and no gas can be released by the regulator.
Anyone can replace one. Just find the tip that sits in the the pilot flame when you try to ignite the pilot light. Follow it down to the regulator and unscrew it. There is no gas involved. It is Ultra Low Voltage. No danger.
Be sure to turn off the power to the unit before you begin removal. Take it to the parts store along with your furnace brand and model number. If you see any identifiers on the regulator, note them and take them with. When you replace it be sure to have the sensor end up in the flame of the pilot.
Sep 29, 2009 | Heating & Cooling
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pilot light wont stay lit.want to clean the orifice
You shut off the gas.
Shut off the power.
Remove the gas valve and burner assembly.
After cleaning and reassembly you must purge the system and use a gas leak detecting soap to verify no leaks before turning on the power.
Apr 15, 2009 | Heating & Cooling
Can't find instructions on lennox gf 8 series furnace
Does it have a standing pilot light? On new units, there is an igniter and not a pilot. But if you have a standing pilot, you will move the gas valve to "pilot" and push down the red button while holding a flame under the pilot located by one of the jets. Once it lights continue to hold the button down for a minute or so and then release the button. The pilot should stay lit. Then turn the dial to the on position. That's it.......... If the pilot won't stay lit then the thermocouple is bad and needs to be replaced.
Apr 05, 2009 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
