When it starts up it say a file is corrupt and to check chkdsk utility then the screen turns blue and says it has detected a problem in windows and needs to shut down
  • joecoolvette
    joecoolvette Oct 09, 2010
    Easiest way to solve your problem, is to use the Restoration Disk (CD) if you have one for the computer. If not see if you can contact your computer manufacturer support for it. The file indicated that is corrupt is a Windows start up file. (Boot file) The reason it is corrupt? 1) May have been caused by a virus 2) May be damage on the Platter inside the Harddrive, (Sector and Track), that the Boot file needed is on. 3) May be the usual Windows 'thing'. (Windows is a funny{?} animal. Just looses it sometimes) Sometimes using CHecKDiSK works, sometimes it doesn't. I'd go with the Restoration Disk, and do a Repair. (Non-Destructive Installation)
    Problem Solver:
  • 12 Answers
You might try and use the original installation cd and see if you have an option to boot into recovery console. Try running chkdsk from there....
Do not try to reinstall the os using the disk. Just go into recovery mode....
Here is a walkthrough....
http://pcsupport.about.com/od/fixtheproblem/ss/rconsole.htm
Posted on Oct 09, 2010
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
My eee pc is saying files missing or corrupt
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive. or an easier way to run the chkdsk utility Windows 7 chkdsk http://www.w7forums.com/use-chkdsk-check-disk-t448.html Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. also download the registry cleaned cc cleaner
http://download.cnet.com/ccleaner/
You can also run a free registry scan using utilities from http://re7.info http://www.download3000.com/showarticles-182-0-date.html System Utilities. http://www.download3000.com/showarticles-178-0-date.html Optimisers and Diagnostics. http://advanced-systemcare.soft32.com/ One-Click Free System tool for PC tune-up and maintenance. Registry repair
Feb 06, 2013 | Computers & Internet
Windows 7 detect hard disk failure in acer Laptop 5336-2524
The chances is good that the hard drive is faulty when Windows says that. The best is to backup all your information and get a qualified technician to test the hard drive properly and then to replace the hard drive if faulty.
http://answers.microsoft.com/en-us/windows/forum/windows_7-system/windows-detected-a-hard-disk-problem/04a301bc-e063-429d-ac93-f8f4062e5d62
If it is not the hard drive then it might be your hdd controller on the motherboard. If that is the case you will need to replace the motherboard. But a motherboard can be expensive. In that case you can get rid of the laptop and rather buy a new one.
Jan 14, 2013 | Toshiba Satellite A215-S5822 Laptop
Only 60 gb the remaining space desapeared ???I tried to format was ok after installation of windows xp profesional ok trying to install xp sp 3 totally bloked ???
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. Then try to install service pack 3 again
Hope this helps.
Dec 16, 2012 | Western Digital WD5000BPVT Scorpio Blue...
Dell labtop with windows xp pro nostics says corrupted cmdide file how do i fix pls.
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. Hope this helps.
Dec 16, 2012 | Microsoft Windows XP Professional Full...
My insignia D300a computer is saying Window can not start because imy windows file is missing or corrupt
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
hope this helps
Oct 28, 2012 | Computers & Internet
Chrome.exe - corrupt disk the file system structure on the disk is corrupt and unuseable. Please run the Chkdsk utility on the volume C:.
While installing Google Chrome, the installation program detected problems with the file system and wants you to run chkdsk to repair them. Either go to a cmd prompt (or click on Start, Run) and key-in chkdsk /f The /f instructs chkdsk to fix any file system errors it finds as it checks your hard drive, You will receive a message the the disk is currently locked and asking you if you want to run chkdsk the next time the system starts, Respond with Y. Then restart your computer. You will receive a message that a disk check has been scheduled - allow it to proceed. Chkdsk will execute and repair any problems it finds with the file system. After completion, your computer will start up normally. Now you should be able to install Chrome.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jul 13, 2011 | Google Chrome
My Dell Inspiron E1405 is getting the blue screen of death before starting up windows xp. It has the stop codes 0x00000024 (0x001902FE, 0xF8C7E4D4, 0x0F8C7E1D0, 0x83622816) it tells me to uninstall any...
STOP 0x00000024, 0X0000024, 0X24 or NTFS_FILE_SYSTEM = this stop error means that your NTFS file system is corrupt and this is practically impossible to fix - absolutely everything on your hard disk is trashed. The only reliable way to fix that is to reinstall Windows.
Nov 02, 2010 | Computers & Internet
Dell Laptop Inspiron 6400 - "Stop Error Screen" appearing
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
There are two ways,you might be able to fix it
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragmenter tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware).
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
No boot up
Solution :
  • Run chkdsk /r or chkdsk /f to detect and resolve any file system structural damage.
  • After you use the Chkdsk tool to repair the corrupted NTFS volume, rename %SystemRoot%\System32\Drivers\Ntfs.old to Ntfs.sys, and then shut down and restart the computer.
  • Try disabling any virus scanning programs, backup programs, or disk defragmenter tools that constantly monitor your computer.
  • Run any system diagnostics that are supplied by your computer manufacturer, especially a HDD check.
Jun 06, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
