Question about Kenmore Elite 45986 Front Load Washer
HE5t Kenmore Elite
What is code F29?
Door locked and won't unlock???
  • 1 more comment
  • She5876 Jun 04, 2008
    They are sending out a new one. I hope I have better luck this time. Thank you.
  • She5876 Jul 07, 2008
    They replaced the door lock switch.
  • Noire Jul 14, 2008
    Our HE5 will get to one minute of finishing its cycle and then stop.  The only way we have been able to get it to unlock is to hit the circuit breaker - not convenient.  I was wondering if there was some other reset code we could use.  The manual says to press the cycle button.  Did that; didn't work.
  • 240 Answers
Non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
Posted on Jun 03, 2008
They had to replace the door switch.
Posted on Jul 07, 2008
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Code f29 will not start
The error code F29 indicates a problem with the door lock assembly. I recommend replacing the door lock assembly part number 8183270
Please see the instructions provided below.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Sears Home Services
SAFETY NOTICE: Be sure to disconnect power to the appliance before performing any repairs. If you are not comfortable with doing any voltage checks that might be recommended, please contact your local service provider for repairs. Be aware that there could be sharp edges inside the appliance that could cause cuts or other injuries to yourself or others.
Apr 28, 2015 | Kenmore Elite HE5t Washer
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Code dL F is diplayed
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Sep 02, 2011 | Kenmore Elite HE5t Washer
My Kenmore Elite is getting to hot. It flashes f-29
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated.
Check the above link for an detailed article above the same F29 error.
Courtesy:JSROCK - A senior expert of fixya.
Jun 10, 2010 | Kenmore Elite Oasis ST 7806 Dryer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Code F29 is not in the booklet and I can't open the door, is there a way I can fix this because sears can't come out till Thursday, I have so much laundry to do
code f29 in my book is Door Unlock Error Possible causes/procedure are as follows: 1 door lock mechanism is broken 2. door switch/lock unit failure. a. check door switch/lock unit for foreign objects. b. unplug washer or disconnect power. c. check wire harness connections to the door switch/lock unit and central control unit (ccu) d. check door switch contacts E the resistance of both door coils between pin 1 and 3 should be approx. 320 ohms... the door can be unlocked manually... to do this you 1. unplug washer. 2 remove the lower kick panel (i think 2 screws on bottom hold it on) 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a 1/4 of an inch or until a click is heard. 6 you should now be able to open the door.
Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
534 people viewed this question
Sal De
 Brian Main
Brian Main
