Question about Evenflo Baby Gear
Front wheel whole assembly model # 4951G3 blue
4 Suggested Answers
mrgreenz
  • 962 Answers
SOURCE: wheel bearings?
I think you can. as long as there is not damage to the outer casing of the bearing.
Posted on Oct 28, 2008
  • 21 Answers
SOURCE: how to change front wheel bearings on 2000
quite a difficult job without the use of a press but if you can see a circlip either side of hub you can change just bearings but normally you would have to press drive flange out of hub first to see any circlips
Posted on Aug 20, 2009
  • 9 Answers
SOURCE: Sheered off stud. Easily replaced or whole new wheel hub assy?
Should be able to have the peice of stud that is left in the tire taken out and a new stud pressed in!!
Posted on Sep 24, 2009
How do I replace a tire on a pride maxima sc900v 3 wheel scooter?
Hi. Ring monster scooter parts the rear wheel assembly cost $132 dollars there is no mention on the front wheel assembly they might help U with more information 800-798-0325. ... Cheers
Sep 28, 2016 | Pride Luxury Line Maxima Scooter - 4 Wheel...
2008 Dodge Avenger wheel hub replacement
The front bearing comes as a hub assembly, so you should be able to unbolt it from the spindle. You still have to take the axle shaft out.
Jun 03, 2013 | 2008 Dodge Avenger
How to change a front wheel bearing on a 2007 toyota tacoma 2 wheel drive pickup truck
The bearing & hub is a whole assembly for this model, start by removing the brake calipers, the removing the rotors" a couple taps with the hammer should loosen it" , after removing the rotors the hub & bearing assembly is held on by 4 #17 bolts, after you get the hud and bearing assembly off you will need a tool called a bearing split plate ,to split the hub and bearing off each other. Now you should have the new bearing assembly ,inner wheel seal, and hub set together" this is when you need a press". Press the hub onto the new bearing assembly.And thats it! Its ready to go back on the way you took it off.
Mar 02, 2013 | Cars & Trucks
How do I change the front wheel bearings on my Honda? I tried to do it before, but the whole axle assy seemed to want to come apart! is this normal? Any help will be appreciated.
Yes. the whole axle assembly has to come apart. This is the way it is with front wheel drive. The bearing assembly simply bolts to the steering knuckle on your vehicle. This at least makes it do-able (it can be done without a press). However, you will have to press (or knock) the hub assembly out of the bearing. This can be done with a hub puller adapter and a large slide hammer. Pull the hub out of the bearing before removing the steering knuckle. It makes life a whole lot easier. Then remove the steering knuckle so you can remove the bolts securing the bearing assembly. Then you will have to beat the bearing assembly out of the steering knuckle. (They can get pretty stuck!)
May 20, 2011 | 1994 Honda Accord
Bearing on front wheel
What about it? Most people question if you can just replace the bearing, or do you need to replace the whole hub assembly. Unfortunately, need to replace the whole wheel bearing hub assembly.
Dec 16, 2010 | 2004 Chevrolet TrailBlazer
Need one 8" wheel
gajoey, that is in front wheel?
If it then this site can help you:
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
But you cant buy only one wheel for front wheel. You need to buy the whole front wheel assembly.
Hope it help your problem.
Jan 14, 2010 | Graco Quattro Tour Travel System
How do you replace the front wheel bearings on a 1990 buick lesabre?
i just replaced mine! got them off ebay both for a hundred. its the whole hub,its easy!
Jun 21, 2009 | 1992 Buick LeSabre
Broken wheel studs on 1996 grand am se- passenger front
usually they are an assembly but when i get crazy and damage studs i raise and support both front wheels so i can turn them and slowly move the hub where you can fit teh stud in and use an open lugnut to tighten down it will pull the stud in (i use an air compressor for this)
Apr 28, 2009 | 1996 Pontiac Grand Am
Front wheel bearing/drivers side
If the truck doesnt have a hub assembly then just pull the wheel off and pull the rotor off the bearing will be inside the rotor on each side. If it is a hub assembly then you have to buy a whole assembly and its made in it.
Jan 02, 2009 | 1999 Ford F250 Regular Cab
GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Jan 13, 2008 | Baby Gear
Baby Gear Logo
51 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
