Question about Whirlwind FH-778 Air Conditioner
Air conditioner problems
My central air condititioner was running last year now it wont kick in it just starts to freeze on the unit in the house the furnace part
    Problem Solver:
  • 5 Answers
Also check if you can see the evaporator coil is dirty, dirty filter some restriction on duct or the bolwer motor is not work properly or low refrigerant charge came to frozen indoor coil
Posted on Aug 07, 2008
  • 254 Answers
Check your filters first. Replace if needed. Also check that the evaporator fan or blower fan in the furnace is running. If this does not fix it you most likely have a low refrigerant charge.
Posted on May 30, 2008
My motion light on the garage comes on everytime my central air compressor kicks on outside my house.New 4 ton unit 1 year old,is this a short in the light problem or something else?
No it is caused by the power fluctuation when the voltage drops from the compressor starting up...
You may have a bad connection from the power Co. power line or too light of wire coming into the house.
Aug 27, 2011 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
Capacitor is out? Compressor won't kick on.
yellow line from capacitor to compressor has nothing to do with coil freezing up. sounds like your low on charge again, dirty filter causing coil to freeze, no blower operation, dirty coil.if system low again you might want to start looking for a leak.
Apr 26, 2009 | Intertherm P3RA-036K Air Conditioner
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
90 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
