Question about Kenmore HE2 Plus Front Load Washer
Makes noise and doesn't run. Tumbler moves freely and is secure. Belt is in place ane in good condition.
  • sdewitt2 Oct 09, 2010
    The noise is comming from the moter that is frozen. What is my best option?
    Thanks. It was rather obvious, wasn't it. The only question is the cost?
    President:
  • 1,554 Answers
The noise may tell us what and where the problem is depending on the noise type. It also indicates there's power getting into the machine. A humming noise from the drive motor means the rotor is getting locked when the motor is turned on but turns freely when turned off. Verify if this condition exist then let me now. Describe the problem explicitly particularly the noise.
You don't have to accept, reject, or rate this solution to add information or, post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 09, 2010
  • Jahn27
    Jahn27 Oct 09, 2010
    The motor is frozen, therefore the only viable solution is replacing it.
  • Jahn27
    Jahn27 Oct 09, 2010
    Yes it is obvious.
    The motor costs about $140 to $170. Enter the model number of your machine here or here then look for the motor.
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
Will not complete cycle all the time, make a noise like not getting good power to run
Highly possible that the belt is slipping and you will need to replace them, In the first place remove the back cover and check the movement of the drum , if there is friction you will need to check the bearings and the drive shaft. If you observe a slack belt or one which move freely when tugged, then you need to replace it.
Check this link for tips. How to replace the belt on washing machine Bosch
Sep 04, 2014 | Siemens WFXD5200UC Front Load Washer
Ive just installed a new door kit onto my fisher and paykel de45f56a dryer. It has never had a door as it was cracked when purchased so the dryer has never been started. I have now fitted the door however...
yes, double check the switch first. it sounds like the motor is not even moving, since the dryer was never used before sometimes there is a "tab" or locking mechanism to keep the tumbler form moving during shipping.
Mar 27, 2017 | Dryers
How to put back belt and tumbler
If it is already apart.... two people will make it easier but if it is just you...get something to support the drum while aligning it between the front and rear supports, make sure the belt tracks well and the pulley is secure before you replace the back. There will probably be a gasket in the front, make sure it is not doubled over and is in place before securing the drum. Before you tighten it completely look to see and try to rotate the drum by hand. It should move with some resistance but not with much difficulty.Good Luck.
Jan 22, 2011 | Dryers
Dryer tumbler does not spin freely. Makes grinding noise. checked belt and pulley. ok. two wheels that the tumbler rests on, one wheel is free wheeling, while other is stiff.
These wheels are your drum rollers,and you should go ahead and change them both out while you're in there. We have parts so callus with your brand and model number and we'll be sure to get these out to you right away to get you up and running again!
Sep 11, 2009 | Dryers
When the car starts moving there is a loud squeeling noise out of the front driver side of the car then when we stop moving the noise stops
Could be a loose or worn serpentine belt check to make sure it is in good shape. also take a look under the hood and make sure all the pulleys are moving freely when the engine is running.
Mar 08, 2009 | 2003 Honda Accord
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Drum problem
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
Kenmore HE2 Plus Front Load Washer Logo
118 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
