Question about KitchenAid KSRS25IL Side by Side Refrigerator
Kenmore refrigerator water dispenser problem
Our kenmore refrigerator is about 5 years old. Within the past year we have noticed that the water dispenser will dispense something with the water that looks like a wet piece of paper. If you let it stick to the side of your glass, it eventually looks slimy. You can also lift it out of the glass and it seems to be some sort of slime. It has nothing to do with the filter. We have changed the filter several times in the past year with no change to the algae/slime. It seems to be on the sides of the tubing that runs through the refrigerator before being dispensed. Any suggestions on how to get rid of whatever it is?
I saw a post regarding a Kenmore refrigerator that mentioned a problem with slime in the water line. We have the exact same problem but with a KitchenAid KSRS27IKSS01 model. Has anyone found a resolution?
  • provobis Jun 05, 2008
    I seem to have the same problem though I would describe the stuff in the water dispensed by the fridge chilled water spigot as flexible translucent skins that float around in the water. I too have changed the fridge filters and even removed them to try and flush the stuff out of the fridge tubing but it's still there. But I still have a question if anyone is following this thread. Do I understand NextGuy to mean there's algae in the water source or source pipes supply? We have a well which supplies water to the whole house which is treated and shows no signs of the "skins" in the water up to the fridge. The skins appear only between the back fridge water input and front water outlet spigot. Does that mean the algae is invisible or does not materialize until it gets to the fridge? My kitchenaid model is KSRD25FKWH01 mfg date 07-01
    Scholar:
  • 110 Answers
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
Posted on May 30, 2008
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
The top shelve of kenmore refrigerator stay too cold
I think my problem seems better now that I"ve lowered the temp to almost off. Oh by the way, what made you think I have a side by side. What I do have ias a 10 year old single door kenmore.
Jan 09, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Kenmore frigde not dispensing water
Replace the water valve.On the back at the bottom you replace the part the water line is attached to.In the pix i'll show you what a typical valve looks like.754d79f.jpg
May 29, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
KitchenAid KSRS25IL Side by Side Refrigerator Logo
470 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
