Question about ViewSonic Computers & Internet
Get window with "No signal-Digital" Thought it might be over heated video card but switched cards out and get same trouble report No Signal Digital.
  • ash4288363 Oct 08, 2010
    I will not be able to try this fix until tomorrow (10/9/2010) will get back to you then. Computer system is at my place of business. I start work at 9:00 a.m.
  • 4,737 Answers
Well, let me add you one more thing, have you tried the same monitor on another computer/Laptop? If not try it, first, we need to find out the culprit, and then i'll assist you how to fix it if it's possible from users end.
If it powers up without any problem, then you also need to check the video cable. Of course, you were right, the video card overheated could be the issue, but in most cases, that's not only the case, even the video cable can cause the same. I hope there's no problem with the monitor since you can see the message "No Signal-Digital"..
Let me know when you are done.
Good luck...
Awaiting...
Posted on Oct 08, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 08, 2010
    No problem... All the best......
What is dvi no signal
Digital video input no signal,on a monitor usually indicates that the video cable is not supplying a signal.Could be a faulty cable, or a bad connection from computer or the monitor...or a bad display driver / faulty video card.check connections ,try with different cable and monitor.
Feb 11, 2015 | Microsoft Windows Vista Ultimate Edition
Hp monitor 2031s does not scan signal from gateway gt5432...
Go back to Dell monitor. Remove any video drivers from hp.change video resolution both in windows and in video card settings to standard 1024 x 768 (yes it will look horrible) then hook up hp monitor. Don't install drivers if prompted get them from hp website then adjust resolution through video card settings after drivers installed which probably require restart.
Dec 01, 2013 | HP Computers & Internet
Monitor say RGB no signal?
If the monitor works with other computer then the video card in the computer where the monitor does not work is bad. You need to replace the video card. If the video card is on the motherboard, just replace it with a video card that fits into one of the PCI slots. If you were using VGA then purchase a PCI VGA Video Card.
Apr 09, 2012 | Computers & Internet
Windows Media Center can't detect a TV signal from a Sabrent card
If you have hd card, it might be your cable company not providing hd signal. If you have analog card, and have HD signal that will cause it too.
Nov 30, 2009 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
No Signal and BIOS troubles - new video card
try using the onboard graphics instead and remove the graphics card. then uninstall all the graphics card drivers and software and reinstall again. make sure you install 32bit or 64bit depending on what your operating system is. you can find out if it's 32 or 64 bit in the welcome center of vista.
Apr 05, 2009 | Acer X193W LCD Monitor
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
T3092
That problem would either be with your video driver or your video card or both.
I suggest looking up your audio device whether it be a card or onboard.
If its onboard, the manual for your motherboard will have it.
Update the drivers.
If its the video card faultering, i suggest buying a new one that fits your motherboard.
The socket size for your video card will also be found in your motherboard manual.
Oct 23, 2008 | E-Machines eMachines Desktop PC
My VX924 Green Led Blinks until fully booted to windows
ok if what im understanding is you tried on another computer and it worked great
the monitor is not your problem the problem lies with your video card
the video card could be outdated
the video card could need updated software
the video is haveing a conflict with another IrQ on *********** board this is common in computers haveing conflicts
now if your not use to computers i would suggest to take it down to nears computer tech. store and have them set your IrQ for you this can get confusing
ask them if they can show you a walk threw on how to set the IrQ incase this happens again say if you do a restore on your comp i know you dont want to pay for it again to have them fix it
or you can call "GeekSquad" they can come to your home and fix it for you and show you a walk threw this might be better for u
i hope this helped you alot
May 25, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
41 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
