Question about Haier XQG50-QF802 Front Load Washer
Spin cycle the spin cycle has stopped
  • 4 more comments
  • staylordtayl May 30, 2008
    spin cycle not working any suggestions
  • staylordtayl Jun 02, 2008
    great thanks
    Looking for a quick easy way to cool a small frame house besides window units, any suggestions?
  • Anonymous Sep 11, 2008
    doesn't spin
  • qqw4303 Sep 11, 2008
    doesn't spin and drain
  • darren Airey
    darren Airey Nov 13, 2008
    i have just tried to put my washer on a quick wash cycle 29 mins the water has pumped in as normal then i notice washer does not spin you can hear something which ipresume is the motor trying to kick in like a clicking noise any help would be appreciated many thanks.
Oh thank you
Posted on Jun 02, 2008
Remove and repair the Spin Switch located under the lid. The body of the switch had come apart somewhat. I removed the Switch by removing two screws. I put some Super Glue in the seams where it was suppose to fasten and held it for a while and remounted the switch and it works fine. I hope this helps. Before working on it be sure to unplug the machine.
JP Banks
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Washer enters spin cycle but does not advance past the spin cycle
William, do you mean it does not stop after spin? Usually spin is the last cycle. If it stops but does not switch after some time and the settings dial does not move, its a different story.
Aug 19, 2013 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Maytag neptune FAV6800AWW top load washer gets to 32 minutes left and goes no further. It starts to cycle for about 5 seconds and stops for about 35 seconds... over and over and over
Is the machine in Spin Cycle when this is happening? What part of the washer selected cycle does the Cycle Status LED say the machine cycle is in.
If it’s in the Spin Cycle I think you have a clutch issue. Do you take any error codes to the LED console display such as dC or uC?
If you stop the machine in that cycle and do a Spin Only cycle will it complete?
Do you want to DIY the fix? Let me know and I will try to help…..Rich
Feb 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle stops too sharp
The clutch isn't disengaging at the end of the spin cycle. The cause is usually the controller not progressing either mechanicaly or electronicaly.
Nov 04, 2009 | Maytag Performa PAV3200
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Haier XQG50-QF802 Front Load Washer Logo
265 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
