Question about Garden
I have a John Deere compact tractor model 2210, the 3 point hitch slowly lowers on it's own after about 20 Minutes of use. After that the implement can not be raised. I checked the fluid level and it is per specs. When I first start the tractor the 3 point hitch and the control valve that controls the rate of descent, work the way it should. It doesn't matter if I'm using a bush hog or a blade it still acts the same. The front end loader works still works fine while the hitch will not raise the implement, any help will be appreciated thank you I
HarryHarley
  • 343 Answers
SOURCE: looking for a user manual for a John Deere Model 5500
Find your manual here:
http://www.deere.com/en_US/ProductCatalog/HO/servlet/servlet/com.deere.u90785.cce.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=HO&searchCriteria=5500&submit=Search&language=english
Posted on Dec 24, 2009
nova2nv
  • 197 Answers
SOURCE: JOHN DEERE LAWN TRACTOR 145 SERIES, RUNS OK
When you start to have this problem loosen the fuel cap and see if that makes any differance,there is a small vent hole in the cap that can get plugged.When it gets plugged your fuel tank will develop a vaccum and cause you engine to starve for fuel.Im not sure on this model but the older 100 series had a problem with the fuel line being pinched between the frame and the tank.
Posted on Feb 22, 2010
  • 1456 Answers
SOURCE: CANNOT RAISE OR LOWER RIGHT
Hello
Read the instructions. This may seem obvious but many of the problems that occur when putting together a Bowflex happen because directions are ignored or only referred to casually. Read each step completely
Loosen hardware. In some cases, problems can occur if you have made some of the hardware tight before it should be. The manual will instruct those working on the construction of the machine when they should and should not tighten bolts completely. Reading the manual completely will help you know when bolts should and should not be completely tightened.
Posted on Jun 20, 2011
SOURCE: Three point hitch on 2020 Jogn Deere Tractor will not raise.
In the worst scenario, the follower, or the piece that senses load on the control shaft , may have broken. Several causes could be the culprit, but happened on my 2520 . Fix requires total disassembly of final drive and differential to remove control arm and repair the follower. Good luck.
Posted on Jun 27, 2012
  • 14585 Answers
SOURCE: new Holland tractor
Sensor, wiring or computer failure.
Posted on Jun 26, 2016
Testimonial: "What sensor?"
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
I just got 7210 john deere tractor i cannot get the three point hitch to go down what can i do?
We have had problems with light rust on the cylinder walls. Honed the rust out and lift worked great
Feb 05, 2012 | John Deere 7200,7210 All W/o Cab Tractor...
I need to know where to add hydraulic fluid in a John Deere 2010
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 04, 2009 | John Deere 4000 201000-> Gas & Diesel...
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
Sep 13, 2009 | Garden
Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Sep 10, 2009 | Garden
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
