Question about Royal VF1012mx Shredder
Yesterday when i was using it it started to make a really loud noise. reverse makes the normal noise but on auto it sounds bad. i cleaned out the inside but there is still paper stuck that i cant pull out. what do i do? do i need to clean out the blades? if so how do i do that?
    Genius:
  • 1,218 Answers
It will not hurt to pour some lightweight shredder oil onto the cutting shafts....depending on how much you use the machine this should almost be part of a regular operation... I normally suggest to customers to pour the shredder oil onto a sheet of paper in an "S" pattern and then shred the sheet of paper....also shredders will work more reliably if you only shred about 70% of the rated capacity...less strain on the motor and parts and this results in fewer jams and longer machine life.
Posted on Oct 09, 2010
Differential problem?
If your speaking of hydrostatic drive,not clutch type,after a lot of use this "sound"becomes a normality.The drive motor(hydraulic)is worn.Mine does the same thing,on all thre of my mowers.I don't concern myself with it.Even my drive motors on my Toyota skidsteer make that same noise.But I know they're ok.Just keep changing the filter on the hydraulics every 100 hours or less.If it doesn't bother operation,just you,then i don't believe anything is really bad wrong.As time goes on,with use,things wear.BUT,they're finding there position is all.Their worn into place.You rarely use reverse,thats why it don't make noise in reverse.But if it bothers you that bad,replace the drive motor everytime it starts making that noise,or replace the mower.
Apr 15, 2014 | Garden
Beko WME8772W washer not working
clean the filter first
look in the pump for any bits in it
Feb 06, 2014 | Washing Machines
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
I have a 99 Ford Superduty 7.3 Diesel. It is making a really bad grinding/screeching sound just after it starts and is warming up. It wouldn't ******* off all the way even after the key was turned
indicates that the starter motor is stuck in the ring gear
possibly faulty starter relay or starter solenoid
pull the starter as the pinion over ride clutch is probably damaged ( noise ) and have the start circuit and relay checked
have the starter bench tested for serviceability by an accredited auto electrician
May 03, 2017 | Cars & Trucks
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
My airconditioning was on and then started making a loud noise
FROM YOUR DESCRIPTION IT SOUNDS LIKE THE A/C CLUTCH ON YOUR COMPRESSOR IS GOING BAD. U EITHER HAVE TO GET CLUTCH REPLACED BY EXPERIENCED COMPRESSOR REBUILDER OR REPLACE COMPRESSOR AS A WHOLE
May 06, 2012 | 2003 Buick Century
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Royal VF1012mx Shredder Logo
256 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
