Question about Canon MX700 Office All-In-One InkJet Printer
When I print, there are routine gaps, like ink cannot get wherever the rollers are
  • 386 Answers
Hi Good day!! try to align your printer. to do that go to your printer properties and the printing preferences there's a "maintenance tab click it and then you will the "print align"
Posted on Oct 09, 2010
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
Canon Pixma MP800 Prints a 1/4" black stripe on back of page. Is emptying the large PGI-5 cartridge in record time. Have replaced cartridge, run cleaning and maintenance routines. Cleaned bottom...
I have seen this before but it has not caused the black to run out quickly. if you look into the machine you will see at one end of the platen roller it will be swimming in ink. As the paper passes over the roller it will deposit ink to the back of the paper. now why is the ink getting there? Well its just possible that air hole in the cartridge is blocked but you say you have replaced the cartridge. Ah but with what? are you using recycled cartridges? they may be filled with ink and not dye which is what originals use. Dye is much thicker than ink and ink maybe leaking from the cartridge. The seal in the carriage may not be making a clean contact with the base of the black cartridge causing it to leak when the carriage is moving. Check those out and repost if still having the problem.
Good luck
May 16, 2011 | Canon Office Equipment & Supplies
My Canon IPF 9000 keeps tearing up the paper when loading, especially the thinner stuff, it gets caught up under the ink carriage and then bunched up and then I have to switch the whole thing off and...
Use only the recommended printing paper in your printer or else the rollers will chew them off and cause more harm.
A thin paper can move off with the roller unlike a thicker one as the gap in the roller is set for the printing paper.
So please check this out.
Aug 28, 2010 | Canon imagePROGRAF iPF9000 InkJet Printer
Why am I still getting banding even though test prints are ok.
Sounds like you've picked up some dried ink on the print head or ink holder. I would suggest removing all the ink cartridges and the ink holder (see directions from Canon) and clean the bottom with rubbing alcohol and a Q-Tip or cotton cloth. DON'T use paper towel, it leaves lint. Check the rollers also to make sure they don;t have ink residue on them. Be cautious when working inside your printer.
Jan 24, 2010 | Canon i9100 InkJet Photo Printer
Problem with printing - streaks yellow and green not all colours are printing, not used for some time but new cartridges have been put in
Follow these steps to print a nozzle check:
  1. Turn off the Stylus CX.
  2. Load letter-size paper in the sheet feeder.
  3. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds.
    The Stylus CX turns on and prints a test pattern, which includes anozzle check. Shown below are some examples of what the nozzle checkmay look like.
If any of the colors is missing, perform a head cleaning routine. It appears that the magenta head is having some problem. Try printing again after performing a head cleaning task. If the problem continues you might need to replace the head.
Thank you.
Oct 11, 2009 | Epson Stylus DX4200 All-In-One InkJet...
The hp psc 1600 is getting dark shadowing when we print items we then brighten up the page but it reverts back to dark shadowing again.
clean the rollers with the help of maintanance option in the printer properties. if not solved check the ink service station unit inside the machine is full with waste ink , clean the waste ink pads and refix it. clean all smudged inks from the paper pickup rollers
May 25, 2008 | HP Office Equipment & Supplies
Lines
This can be caused by another of things, but the 2 of the most common are faults with alignment or dirty rollers.
Thing to do first is run the cleaning routine and then alignment routine..
Clean the rollers with a dry clean cloth
Jan 01, 2008 | HP Officejet 4215v All-in-One Printer
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
Canon MX700 Office All-In-One InkJet Printer Logo
364 people viewed this question
old marine
old marine
