Question about JUMP START SYSTEM
I have lost the ac recharging power supply FOR A VECO10S BUT NOT HAVE THE ELECTRIC ESPECIFICATIONS, VOLTS, AMPERS AND ALL THIS, PLEASSE HELP ME, RADIOSHAK NEEDS THIS DATA FOR SALE ME ONE.
  • 10,291 Answers
12 volt 1 amp or greater
Posted on Jan 23, 2014
3 Suggested Answers
  • 142 Answers
SOURCE: i have lost the ac recharging power supply, where
check the volts and micro ampres on the back or by the jack.
then go to radio shack, they have universal ac power supplies
Posted on Jan 20, 2010
  • 4 Answers
SOURCE: I need a vector jump starter ac adapter. Lost
Radio Shack
Posted on Jul 10, 2010
I have a Arctic King through wall AC model MWW-12ERN1-MI0 and the compressor will not engage to cool the air. Can anyone help me diagnose and fix this problem?
On the ac unit electric section, check for power at Y1, should have power, possibly to x or c ( common terminal).
Check for power across the compressor contactor, should have power or something is open such as a pressure switch or compressor protection. If there is control power at compressor contactor solenoid ( 24 volts control), then check for supply power on line side of contactor, then on load side of contactor (supply voltage e. g. 230 volts. If all voltages are present, then check the compressor for opens and electric continuity.
CAUTION: electricity is dangerous, can kill and/ or cause fires. Do not attempt if not aware of safety procedures.
Aug 08, 2017 | Heating & Cooling
Can you use a power supply
You can use power supply, BUT you must shure that you have 2 parameter : a) Same Voltage AC or DC b) Same ampers.+same frequency.
God bless you
Aug 03, 2012 | Proform Exercise & Fitness
T23 2647 Think pad AC power adapter lost
No. You must use a power supply that is 16 volts or that is specified to be used with the laptop.
You can find the information about the power consumption (volts and amperage) underneath the laptop. If it says 16 volts then you MUST use a 16 volt power supply.
If you try using a 19 volt power supply you run the risk of damaging the motherboard or blowing the motherboard completely.
Regards.
Mar 18, 2010 | IBM Computers & Internet
I have lost the ac recharging power supply, where can i but another?
Jan 20, 2010 | JUMP START SYSTEM
Ampers for Sony CDX-S2210S CD
If the in-line fuse from the car installation is still attached, check the fuse rating; it will state a figure that is in excess of the demand of the stereo. In other words, if the fuse has 10A on it, it was chosen to fail at currents higher than that. If this unit is only a CD player (no amplifier built-in), it will not likely draw in excess of 2 amperes and probably not over 1 ampere.
If you have no documentation, you can download what you need here:
Sony manuals for your unit
Nov 15, 2009 | Sony CDX-S2210 CD Player
Electric mobility Rascal 265 LE scooter won't run 24 volts dc on batteries no sound or movement
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
May 02, 2009 | Electric Mobility Mobility Electric Power...
Lost ac/dc adapter
Hi, for a 12v 2 ampers device any universal laptop power suply can be used. They usually are tesignedfor about 2-4 ampers so it won't be a problem. All you have to ake soure is the correct polarity, and the changeable dc plug.
good luck.
Mar 20, 2009 | Kogi L7CH Monitor
Lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 26, 2008 | Cobra Radio Communications
JUMP START SYSTEM Logo
239 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
