Question about Jcb Bruder JCB Loader Backhoe
I am trying to find out what the warning symbol lights on my 1989 1400b backhoe mean.Thanks Vince
Dashboard symbols mean
It is the defective bulb warning light. It is a warning that a bulb has failed and needs to be replaced.There is a similar symbol that is an automatic transmission warning light but from your description I believe it is the bulb warning light. Hope this helps.
Jan 12, 2014 | 2003 BMW Z4
Warning light symbol gear with ! what does it mean
Typically, The exclamation mark is in regards to the braking system. Not sure what gear thing your referring to. If you can be more specific, I may be able to find a solution to this warning light you are referring to. Thanks. Sorry couldn't be of more help at this time.
Nov 12, 2013 | 2000 Mercury Sable
What do warning lights mean
Go to Google & put in OBD2 Dashboard Symbols
Mar 02, 2013 | Cars & Trucks
I need a description of dashboard warning lights
i have a light that comes on my audi a3 1.8t dash board .it is round with a cross through it and like a little box on top can any one tell me wat this is thanks
Apr 15, 2010 | 2004 Audi A4
I have an old Ford 550 digger clutch failure
if its a hydraulic clutch & conneted to the same system & its low on fluid then that will be your problem
just top it up & try it you may have to bleed out the system of air if it doesnt work!
Jul 19, 2009 | San d Digger
1999 volvo warning lights on dash do not know what symbol means
1998 volvo s40 right hand drive: there is an orange triangle light with green in the center and an upside "y" in the center of the two. It is between the "up orange arrow" and "a an orange car with an X on it" the light comes and stays on. Dont know what it means. can you help. Thanks
Jan 21, 2009 | 2000 Volvo S40
A symbol lighted up that looks like this (!) what does it mean?
This is the "tire pressure warning" light; this comes on when the tire pressures are lower than the specification required. Please check you tire pressures, re-infalte as needed. Hope this helps; and thanks for choosing FixYa.
Nov 05, 2008 | 2007 Toyota Yaris
Control Lock light remains on
Vince, press and hold the keypad next to the lock symbol. (heated dry?) see if the lock light goes out. Catriver..post back
Mar 19, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Jcb Bruder JCB Loader Backhoe Logo
298 people viewed this question
Top Jcb Toys Experts
Gary Nitowski
Jerry Kramer
Jerry Kramer
Are you a Jcb Toy Expert? Answer questions, earn points and help others
