Question about Sharp R-220HW Microwave Oven
Turning table not turning - Sharp R-220HW Microwave Oven
    Problem Solver:
  • 11 Answers
The motor needs to be replaced for the turntable is the hard fix. If it's not seated right, it will not turn. Also check to see if there is residue or dried food stopping it from turning-that's the easy fix.
Posted on Oct 09, 2010
Do you have a glass turning table for daewoo microwave oven of the attached model in the photo
Just one recommendation. When it come to microwave, sometimes the glass turning table could be compatible with other brands. So I recommend that you edit this post and add a picture of the glass table that you want. That way you may have a better chance on getting help.
Jun 08, 2016 | Daewoo Microwave Ovens
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
Turn Table wont turn
if you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Jul 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Panasonic NN-S262SF Microwave Oven
Sharp R-220HW Microwave Oven Logo
71 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
