Have Magnavox tv and remote stopped working. changed batt. did no good. must need to be set with code again. I dont know where codes are anymore.
  • angelhare11 May 30, 2008
    My tv is just a 19 inch portable and it has been working fine for years. yesterday, I dont know if I accidently hit the set button on the remote or not, but all of a sudden I could not change channels or turn up the volume ... I changed batteries and pushed the buttons at the top that say tv dvd sat cab but nothing changed.. Do I need a new remote or is this a simple problem. do remotes just quite like that???
    Sergeant:
    Champion:
  • 310 Answers
Go to this link
http://www.thompsontv.com/rcarc.html
Posted on May 30, 2008
  • khader ibrahim May 30, 2008
    u can get code from this site also
    http://www.replacementremotes.com/tvcode...
  • khader ibrahim May 31, 2008
    Can u tell me the remote is working properly.........if its working means reset channels and check everything is working properly or else u want to change the remote...........
I have a ge universal remote and my tv is a Magnavox can I find the code for my tv with this remote
You can use code search to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote (such as Philips). All universal remotes do not store all possible codes.
Jul 07, 2016 | GE Televison & Video
I have a disney tv and the phillips codes do not work. Does anyone know of different codes besides 0417 and 0115:
Follow the same steps to enter a code but instead of entering code press the channel up button repeatedly until it turns the tv channel and when it changes (dont press up again or else you will have to do it over again). When you get the remote to change channel STOP! and press the enter/ok, or similar button to lock the code in and you should be set. Good luck. If you follow the steps and it doesnt work the first couple of times dont be discouraged, Trust me all universal remotes allow you to set up you universal remote this way i guess they already know people lose the universal remotes instruction manual with all the codes in it! Hope this helps GOOD LUCK too you. Hope this works out for you!!
Jan 02, 2011 | Disney DT1350-P 13" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jan 14, 2009 | RCA RCU404 Remote Control
ZN110 remote
Magnavox codes 002,009,109,118,309,402,408,502,508,510,807, 917
May 11, 2008 | Zenith ZN110 Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
I don't know how to program my remote anymore!
I had the same problem and typed in the model of my vcr instead of the remote model. This is the site I found, although my tv is not on the list, I followed the steps at the bottom of the page and found that code 08 worked for my Phillips TV. I hope this helps all of you with finding your codes and programming your remotes.
http://www.remotecodelist.com/remotes/sharp/sharp_vch982.html
Jan 14, 2008 | Sharp RRMCGA342WJSA Remote Control
Model MW C20T6 Serial # V08613170
the Magnavox TV codes for a phillips universal remote are:
MAGNAVOX 0807, 0002, 0502, 0247, 0919, 0224, 0430, 0402, 0408, 0109, 0715
Nov 18, 2007 | Philips Magnavox 27MS343S 27" TV
I Need Help programming and Need the Code for my remote and TV!
I had the same problem with my REM340 remote trying to program an older Zenith TV. Here is what I found and it worked pretty quickly.
Turn your TV on.
Press and hold the SET button until the light stays on.
Then press the TV button.
Then press the VOL+ button until your TV turns off.
Once your TV turns off, press the SET button again.
Hopefully you can now turn your TV back on and everything will work. Good luck. I know the frustration.
Sep 19, 2007 | Philips Magnavox REM-350 Remote Control
Televison & Video Logo
Top Televison & Video Experts
