Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Pilot lite won't light - Jandy Lite 2 Natural Gas Pilot Light Heater
  • 44 Answers
I believe your heater uses a" Glow plug" style igniter not a traditional pilot.This type takes a few minutes to lite. Be sure the correct pump is running,the gas valve is turned on, and the Bypass valve is at least 1/2 way closed.Also make sure you have at least 10 psi on the filter gauge.
Posted on Oct 09, 2010
My pilot light will only light after i heat the thermal coupler. Even with the button depressed gas won’t flow to pilot until heat on thermal coupler is applied. Is this normal?
No this is not normal .The pilot should lite first then when you hold button down until thermocouple sense the flame and tell pilot to stay Lit .
I think you should change out the whole pilot assembly.
Does this pilot needed to be lit manually or has a sparker
Feb 23, 2018 | Heating & Cooling
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
New thermocouple on GE/rheem water heater pilot still won't lite
does the pilot go out when you let off the button? Or does the pilot not light at all?
If you dont get any gas at all to the pilot the the gas valve is bad.
Of you get a pilot light that goes out when you let go of the button then the therno couple is not reading the flame (needs adjustment so the pilot flame touches it)
did you kink the new thermocouple? or over tighten it at the gas valve.
if it was kinked its now toast,cant straighten them. If kinked and starightened the fluid inside has broken the inner seal and wont work.
Jan 10, 2013 | GE 50 gal. Heat Pump Electric Water Heater
The pilot got wet and it won't lite up ???
There could be water in the pilot line or pilot is blocked and needs cleaning out along with the pilot line .
Dec 24, 2012 | Heating & Cooling
Pilot won't light
check gas pressure check safety circuit if ignitor lites check gas line to it maybe plugged
May 21, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My pilot light is weak and won't stay lite.
try cleaning the pilot light jet, usually gets dust etc inside it. clean it with a pin. but remember do not mess with gas appliances if you are not confident enough. as being cold will be the least of your worries lol
Feb 16, 2012 | Heating & Cooling
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
138 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
