Question about HP LaserJet 1320 Printer
HP LaserJet 1320 - All pages come out crinkled, but fully printed on. If it weren't for the crinkling, we could use the pages!! :~) Paper path has been cleared, all rollers and related openings and compartments checked and there is NO BLOCKAGE!!! Anyonegot any ideas that might help us?? We'd sure hate to buy a new Laser Printer now with the econony & the holidays around the corner... Thanks in advance for any ideas or suggestions....
  • fcam_llc Oct 09, 2010
    Done repeatedly, on previous date based on other recommendations, but that did NOT resolve this problem/ issue. We've also tried using a damp cotton cloth that was dampened with Isopropyl Alcohol instead of distilled water, (damp, NOT WET) and still not luck!!
    Any other ideas? Thanks again for your help...
  • fcam_llc Oct 10, 2010
    I've cleaned the rollers several times, but that did not do the trick.
    When you reccommend non-cotton cloth, what type of cloth are you recommending be used? I'll look into aligning/realligning and/or changing the allignement of the rollers.
    Would a pix of the crinckled printed output from this printer help?
    Thanks for your input/suggestions, and any additional info or suggestions you might have.
    Bruce ;~)
  • HP Expert
  • 2,973 Answers
It seems that the roller that'pull the page in are misaligned either for want of cleaning or for not being parallel to each other. please start off with cleaning them with moist (not wet) non cotton cloth. If that does not work then they will have to loosened, paralleLed and tightened. For this specialist srevices should be sought as it is highly technical.
Posted on Oct 09, 2010
  • Rinoo Kumari Oct 10, 2010
    Resetting of the rollers is the only option left now.
    President:
  • 4,070 Answers
HI! Please just clean the roller with moisten cloth. The problem will be on the dirty roller thats why the paper comes out crinkled. Hope this helps and thank you for using FixYa!
Posted on Oct 08, 2010
Fix Paper crinkling on the left of each page starting about half way down?
Crinkling paper is usually due to either an obstruction in the paper path or a bad fuser, which is the part of the printer that heats the toner so it melts to the page. It is located at the top of this printer. It can be a little challenging to see the fuser on this model, but if you look close you should be able to determine if the fuser is bad. You might also have a bad transfer belt, inspect it closely on the side the has the crinkle.
Feb 28, 2015 | HP Color LaserJet 2600n Printer
HP LaserJet 5n Printer The paper crinkles when we try to print. Thanks, Linda
you have to clean or replace the exit roll which located at rear of the printer
Apr 07, 2010 | HP LaserJet 5n Printer
Paper wont feed through the printer-as it goes thru one corner of the paper crinkles up(right side)
You have a bad fuser unit, very expensive and difficult to replace.
Not worth repairing.
Jan 20, 2010 | HP LaserJet 1320 Printer
My HP 1320 is crinkling every page. I've cleaned everything, changed the toner cartridge, but still have the problem. Ideas?
If the crinkle is a fanning or accordion, it is time for you to replace the Fuser.
This is almost always the reason.
Other then that, small pieces of paper can be stuck in the printing path, often behind the fuser.
Removing the back cover, and then the fuser is the best choice.
Your User Manual provided with the device shall explain how to remove the fuser, though it is relatively simple with limited tools.
Apr 14, 2009 | HP LaserJet 1320 Printer
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Feb 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Paper crinkles
This is what I've seen with wrinkled pages in these machines.
Usually only happens with letter size paper.
At some point a leaking toner was used in the machine the excess toner works its way toward the fuser and builds up on the guide where the paper enters the fusing assm.
You can try to clean the toner thats built up or replace the fuser.
Hope this helps
Jan 13, 2009 | HP LaserJet 8000n Printer
Printer jam upon exit
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Nov 14, 2008 | HP LaserJet 3030 All-In-One Printer
PAPER CRINKLING
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Feb 16, 2008 | Xerox Phaser 6250DP Laser Printer
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 1320 Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
