The picture is really funny the bottom of it when it shows ppl look like midgts n the top looks like they have a big head & thur is a lil black space on the bottom & thur is lines small lines thur out the picture
  • 597 Answers
The reason your television gives a funny display is because there is a problem with the television.
The problem most likely can be either from the lamp or probably there is a burnt capacitor in the television.
Another cause might be that the t-com board is bad and needs replacement.
To check and repair if it is the lamp, turn the back of the television and unscrew it open, you will see some compartments that are covered, under the sheets used to cover them are the boards of the television, unscrew them to have direct access to the main boards.
Check if there is a burnt capacitor on any of the boards, the capacitor might be swollen or looks burnt, so you can replace them with replacement capacitors, ensure the capacity of the replacement capacitor is the same with the initial one.
For the lamp, you will see a light tube, check if it is burnt and replace if it is.
You can replace the t-com board if there is no burnt capacitor or lamp.
Take care
Posted on Oct 08, 2010
  • 30 Answers
You change all capacitors in vertical out put stage &finally change vertical out put ic.
thank you
How do I tell the engine size of my 1978 chev truck
I picture would help greatly . Look at the valve covers . If it has 2 bolts on bottom and 2 bollts on top " 4 total " holding the valve cover on then it is a small block . Now if it has 4 bolts running along the bottom of the valve cover and 3 along the top " 7 total " then it is a Big Block .... Now that will help you pick the " family" of the engine but you still want to know the displacement " Cubic Inches " so here we go . As long as the engine block has never been " Decked " there will be a suffix code that can be decoded that will tell you what the engine came from , what the displacement is , as well as horse power ratings when new. The suffix code is located on a small square pad sitting directly in front of the passenger side head ' Usually hidden behind the alternator " Look at the pictures below to show you location ... At the end of the number there should be 3 letters , those are the suffix code . You can google the letters and see what turns up . A website known as nasty z28 has some really good info . You may need a flashlight , and some good cleaner to get a good look at the number down in behind there ........ Now if the truck has a big block , The number can be in one of two different locations , The first is the same as the small block . However i have also seen mid seventies big chevys that had a pad directly center , just above the timing cover and below the front of the intake that has the suffix code on it there ... If you are having trouble finding the code online and breaking down what it is , Just respond here with the numbers and letters and i will decode it for you .
Feb 15, 2015 | Chevrolet Cars & Trucks
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Where are the freeze plugs located on a 98 cadilac deville? Also, does anyone have a diagram they could share?
the freeze plugs are located behind the exhaulst manifolds thur is 1 plug for each cylinder thur is all so 1 plug on the back of each cylinder head an 1 big plug on the back of ur motor inside the bellhousing that the transmission is attached to.
Apr 05, 2010 | 1998 Cadillac DeVille
Picture is stretched on top and compressed on bottom
the problem of your tv is in the vertical section,you need to replace the capasitor in vertical section .
Feb 18, 2009 | Konka FL2799U TV
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
Sep 07, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Picture too big for screen
on your remote push the arrow key to the right or left side. this should change format and go into customer setup and turn of autoformat
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
Funny coloured screen when i turn on the camera
did someone find the solution ; let me know.. best regards theodore
notodoras@yahoo.gr
Jun 08, 2008 | Nikon COOLPIX S200 Digital Camera
Picture is vertically too big the heads dont fit the screen?
This answer is generic because I do not know the particular model:
You should call the tech support for your set. This may be a fault in the way the address processing is being performed for the display. Sometimes, depending on the model, the service rep can fix this by re-loading the firmware for the set's operation. I have seen failures in the main drive processor for the screen cause this. The solution was to change the board.
Jerry G.
Jan 08, 2008 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
