Question about Solar Ge 24 Hour Timer 2 Pk (ge24t)
General electric 24 hour timer ge5101n can it be used uith cfl (compact Floricent Lighting)
Ge5101 can be used with cfl
The timer turns the circuit on-and-off like a light switch.
Anything a light switch can turn on, a timer can turn on.
Posted on Oct 09, 2010
What size is the resistor in the clock circuit of the GE5101N 24 Hour Timer? Thanks,....Don
Sorry we have no way to look this information up at this website. You need to contact the manufacturer.
May 04, 2017 | Hardware & Accessories
EJ351 is programmed to work. In the on position the light it controls is on properly. in the automatic off position the light is on at approximately half intensity. When the manual control is in the o
This timer is rated for incandescent light bulb only.
With 40 watt minimum.
With 100' maximum distance between bulb and timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej351
EJ351 is not rated for CFL bulbs (or motors etc).
CFL bulbs are considered inductive loads (same as motors), while incandescent bulb is resistive load (same as a heating element).
Both types of loads use electricity differently.
Programmable wall timers are not ordinary on-off switch... unless you use the override switch.
... instead timers control electricity with electronic circuit board.
So when the manufacturer designs the electronics inside the timer, the design must anticipate how the electricity is used by the load.
Older designs like EJ351, and some modern timers, are not rated for CFL.
... however most newer timer designs are rated for both resistive and inductive loads.
Always read the specification sheet for load rating before installing programmable timer.
Nov 01, 2014 | Intermatic Programmable 24 Wall Switch...
I want to see a picture of GE5101n
well search for one through google.com just like I would have to
Sep 05, 2014 | General Electric GE 24-Hour Timer, 2-Pin...
MDL Corp - Manual Timer 301-0004 (Outdoor Lighting)
Timer brand and model are not identified.
Some timers are rated for incandescent light bulbs, while other timers are rated for CFL incandescent and all types of loads.
Open following links to help identify in-wall timer:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
May 28, 2012 | Home
I talk about BRINKS TIMER 7 DAY 46-1022 What type of flourescent light should be use. The manual say "Rapid start flourescent lighting, (the type with no electronic ballast)" Would you say...
S?lo s? una sola lengua. Puedo usar traductor Google para ayudar.
http://translate.google.com/
CFL light bulb has electronic ballast.
Las bombillas CFL tienen balasto electr?nico
46-1022 will not work for CFL, or motors.
46-1022 no funciona para CFL, o motores.
http://respectmyplanet.org/helpthecause/wp-content/uploads/2011/02/cfl2.jpg
Older fluorescent light fixtures have rapid start ballast.
Antiguo luces flourscent han lastre inicio r?pido
http://images.bizrate.com/resize?sq=220&uid=1793142337
Nuevas luces flourscent han lastre inicio r?pido
Electronic ballast makes less noise, use less energy, cause less electrical interference, and the ballast lasts longer.
Balasto electr?nico hace menos ruido, consumen menos energ?a, menos causar interferencia el?ctrica, y el lastre de tiempo m?s prolongado.
Take cover off fluorescent light and read what is printed on ballast.
A cubierto de la luz fluorescente y leer lo que est? impreso en lastre.
Jul 31, 2011 | Hardware & Accessories
I have a G.E. 24 hour timer GE5101N . It says to set time when you want the lights to go on. How will it know when to shut the lights off?
See GE timers on following link to identify timer:
Link has instructions plus large image you can see segments lifted up and pushed down
http://waterheatertimer.org/GE-timers-and-manuals.html#GE510N
Timer knows when to turn lights on-off because segments are lifted up or pushed down.
Push/lift a few segments.
Turn lamp ON
Plug lamp into timer.
Mover switch to Timer ON
Plug timer into outlet.
Manually rotate dial clockwise to see lights turn on-off.
This will show if segments should be up or down.
Set segments for ON OFF times.
Rotate dial until current time lines up with pointer.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 26, 2011 | General Electric Hardware & Accessories
Wondering how to use a 24 hour compact pin timer to automaticlly turn on my lamps ?? bought 1 yesterday but no clue of how to work it !
Pins are usually up for on and down for off, so put them to on for the times you want the lamps on and vice versa, obviously you can check firstly to be sure which way is on and which way is off.
Jan 07, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Just purchased GE 15086 smart timer, can I use this on my lights that have been converted to CFL bulbs?
The 15086 is a straight timer, so it should work with no problems. CFL bulbs only have problems when run off a photocell switch/timer or a dimmer circuit.
Dec 04, 2010 | GE Home
I have programmed this timer many times and never had a problem untril recently. It comes on and goes off at times other than what I programmed it to do. Is it time to replace it?
You probably switched to a CFL (compact flourscent light bulb). This switch only works with incandescent bulbs. Try the Intermatic ST01C switch. The ST01C works with CFL's and LED's. I just ordered one from WestsideWholesale.com They had the best price.
Aug 19, 2010 | Intermatic Programmable 24 Wall Switch...
Cannot set timer properly
This timer only works with incandescent light bulbs. It does not work with CFL's (compact flourscent light bulbs). Intermatic model ST01C will work with CFL's and LED's. I ordered one today from WestsideWholesale.com. They had the best price.
Apr 22, 2009 | Intermatic Programmable 24 Wall Switch...
Solar Ge 24 Hour Timer 2 Pk (ge24t) Logo
661 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
