Question about Bose Lifestyle SA-2 2-Channel Amplifier
I have a Bose companion multimedia system for my computer sound system with a round Bose sound volume and mute control attached... No sound !! Checked all connections. I noticed on the round Bose volume/mute control, that the green display light is very weak and does not change to yellow when pressed to muted. Is the box system blown?
    Sergeant:
    Champion:
  • 387 Answers
From your description it looks like the unit is short inside or the power supply of the unit is blown
let me know if you want to fix the Amp
ecrdn@yahoo.com
Jack
Posted on Oct 21, 2010
My Bose speakers stopped working. They are properly plugged in and seem to be getting power, but no sound.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
hope this helps you
Aug 27, 2011 | Bose Companion 2 Series II Multimedia...
I bought bose c2 but is not responding at all
also
hope this helps you
Aug 24, 2011 | Bose Companion 5 Multimedia Speaker System...
I just bought Bose Companion 2 speakers which I don't know how to connect to my HP Pavillion desktop PC. The pdf instruction booklet does not help. There are multiple jacks (6) at the back of the tower...
You need to connect the speakers to the green jack in your PC.
Check your system sound volume setting to make sure it's not set to MUTE or the volume slider is on or near the lowest position - you don't specify what system you have on the PC so I can't give you an exact pointer but Volume Control generally is found under Programs -> Accessories -> Entertainment.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Bose Companion 2 Series II Multimedia...
I have a companion 5 speaker system up to a few weeks ago they worked fine. I did a whole redo of my operating system on my computer to windows 7 and now it is saying that it say the drivers are not...
This soundsystem us USB based and you'll need to re install the drivers from Bose. If you
can't find proper drivers. you could patch into this soundsystem by taking sound from your soundcard vial line out and plugging it into the aux in on the systems volume control. Also since this system is USB it uses its own sound device. check under control panel --- sound to make sure the computer is using the correct device. Also check your volume control to make sure that the
system is active and not muted.
May 16, 2011 | Bose Companion 5 Multimedia Speaker System...
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
Have bose Companion 2 speakers. Can't get any sound.
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 07, 2010 | Bose Companion 2 Series II Multimedia...
Can't get any sound out of the speaker system, am sure it is not muted. tried taking components apart, restarting and tried with another computer.......no sound. ideas?
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 05, 2010 | Bose Companion 3 Series II Multimedia...
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Bose Lifestyle SA-2 2-Channel Amplifier Logo
185 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
