Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
I have power to the unit, but it won't come on. The remote has new betteries and it has a mark next to clean, I have cleaned the filters but it still won't blow air even just the fan.
  • 73 Answers
Remove the batteries from the remote, need a paper clip to stick inside the "rst" hole behind the batteries. Support@Pridiom.com 201-266-8234 option 2
Posted on Jan 04, 2011
Dryer says clean filter
Elizabeth, I can't answer your question until you provide more detail about the equipment and control thermostat. Brands, type, etc. If the "static" is too great, you should install a NEW filter. Turn the power switch off, then back on to reset the control and the thermostat.
Sep 18, 2017 | Filter Heating & Cooling
Replaced batteries showing Lo replaced with new batteries will not work at all
Makesure the batteries have been put back the correct way and that if there is any corrosion (usually a blue or green powdery mess) on the bettery terminals, clean this off with the point of a sharp knife or scraper. Also make sure you use good quality batteries. El cheapo batteries usually dont have enough power in them to operate a remote. I always recommend eveready gold or similar.
Mar 13, 2016 | Health & Beauty
How to clean filters
Unplug the unit. You need to clean the Ionizer plate periodically. Just run it under water and use a clean sponge if you have to. Let the plate dry completely before reinserting it and make sure you put it in the same way it came out. It's marked with arrows on the side that faces the front. The needle itself should be fine without cleaning but if it has some build up on it GENTLY wipe it off with a dry rag. Wipe towards the tip.
As far as the filters go. I haven't had to clean mine. As strange as it seems I get more dust on the front of the machine and the fan than the filters themselves.
Source: I own one of these in black.
Mar 20, 2014 | Microlux Cherry Wood Finish 7-stage UV Ion...
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Cleaning instructions
Dirt is the biggest enemy of your furnace. It can waste fuel and drastically lower efficiency. Dirt affects all three basic components of your furnace, so cleaning is the most important part of regular maintenance. The three parts of the furnace should be cleaned: the filter system, the blower, and the motor.
The furnace filter should be replaced or cleaned at the beginning of the heating season and about once a month during periods of continuous use. To check the filter, take it out and hold it up to the light. If it looks clogged, replace it with a new filter of the same type and size regardless of the length of time it has been used.
Step 4: Clean blower assembly, belts and pulleys to blower, and motor housing. Cleaning blower is critical if furnace has a squirrel-cage fan, because openings in this type of blower often become clogged with dirt. To clean blower, remove panel that covers filter to gain access to blower or panel on front of furnace. This panel may be slip-fit on hooks or held by series of retaining screws. Access to inside of blower is usually gained by sliding out fan unit, which is held on track by screws.
If power cord to fan assembly is not long enough to permit fan unit to slide all the way out, disconnect cord. Mark wire connections first so you'll be able to reassemble unit correctly. With toothbrush, clean each fan blade and spaces between blades. Then, with vacuum cleaner hose, remove all dirt and debris loosened by brushing. Vacuum belts and pulleys. Wipe motor housing clean to prevent heat buildup in motor.
Feb 08, 2013 | Rinnai Toyostove Direct Vent Heater:...
Remote won't work
GET the camera digital and get the remote control point to the camera digital ON. When you press any keys from r.control you must see the diode LED from the r.control in the display from the camera. If NOT turn ON , replace batteries by new ones with the same mARKS. Clean the contacts batteries very well.Or open the remote c. and clean the keypads !
God bless you
Jan 25, 2013 | BenQ Televison & Video
It won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 01, 2012 | Casio Cell Phones
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
60 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
