Question about RCA HDLP50W151 50" Rear Projection HDTV
Hd150lpw175 Hi, I purchased the capicatorsyou told me to get and pull one off the power board but do not know how to put the new on. How do I do that?
  • RCA Master
  • 8,617 Answers
You have to unsolder the old capacitors and then solder in the new capacitors. You have to make sure to observe the correct polarity and install the new ones the same way as the old ones one side is marked negative dont mix them up do one at a time and notice which side is marked negative on the old one and install the new one the same way. also make sure they have the same uf ratings as the old ones.
Posted on May 30, 2008
  • Sonny Berry
    Sonny Berry May 30, 2008
    Let me know if you need me to clarify anything for you.
I want to know how a 50 inch vizio tv purchased in 2015 could be broken and the vizio people tell me to throw it away. surely someone can help me replace this inferior product.
Hi Pat.
There is a white sticker on the main board/motherboard that has numbers on it. The replacement board numbers or partial numbers,(except last 4 I believe) has to match, if not the TV may not operate correctly, or may not operate at all. Let me know.
Hope this helps.
May 21, 2017 | Vizio Televison & Video
No picture but have sound.
Hi Celeste,
I appreciate your efforts so far.You have sound but no picture. Can you see the backlights? Or is there the on screen LG logo? If the logo is not there it means the backlights in your TV are not working. Mostly it is the inverter board which makes necessary power for the back lights goes bad. Good LUCK.
May 26, 2015 | LG Televison & Video
My son has an acer e4600 and I don't know how to determine what kind of motherboard he neeeds. I have been told by 2 people that he needs one
Motherboards for proprietary manufacturers [such as acer] are built for them and only supplied by them. For all intents and purposes, that board is 'dead'. Acer technicians would advise that you purchase a new CPU [box] which would ship a casing, power supply, motherboard and processor, plus other hardware that a new CPU will ship with from the manufacturer.
It is advised that you approach your dealer or store where this unit was purchased from for additional information.
May 14, 2010 | Computers & Internet
Sony bravia lamp xl2400
Hi,Did you make sure everything was properly closed ?The door cover? It has to be properly shut in order to let the lamp light up.Any clicking noises or like wanting to light up? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's instructions to reset lamp hours: http://www.ehow.com/how_4711082_lamp-hours-sony-rear-projection.html Have a bless one!
Apr 05, 2010 | Televison & Video
Will not power on-- batteries are new- if pwr
Hi:
I was using one of these for the last 8 months, and mine did the same thing, I would push power and the unit will just blink the lights then shut off, But if I hold the power button the light will stay on until the button was released, so I contacted Solo Tech support and they told me the system control board was bad, and in order to get a new board I had to be an authorized servicer for then, I found the board online and the price for the board exceded the price I paid for it. So i deemed it necessary to just purchase a new Scanner....
Dec 27, 2009 | Solo S2 Radar Detector
I have an LP530. Need main circuit board
Try LumenArc. They stock a range of ballasts. If yours is not listed, then email them.
May 09, 2009 | InFocus LP 530 Multimedia Projector
Power board malfunction
There may be four (4) ways the repair could be done:
1. board - an entirely new power board maybe available from the monitor manufacturer or you can Google for OEM provider;
2. board - a refurbished/reworked board may be available, again you have to Google. Both 1 & 2 would require that you search for the actual PCB assembly number;
3. use the power supply board from an identical unit that has defective LCD panel, inverter or other problems/defect other than the PSU; and
4. component level repair - determine which components in the power supply are defective and needs replacement.
All of the above would require time. Time to look for the replacement board, time to determine which component to replace, time to do the actual repair.
Cost - depends on the tech. Of course board assembly would cost more to purchase but should be relatively easy to perform and therefore should not be expensive in terms of service. On the other hand, component level repair often would be cheaper in terms of parts purchases but would cost more in terms of service fees.
Taking into considerations the above factors, it may be more to your advantage to do the repairs yourself (no service fee). Still should you be uncomfortable on a DIY, then the cost of repairs might justify the purchase of a new LCD monitor instead.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 28, 2008 | Acer AL1711 17" LCD Monitor
Ilo 26" TV stuck on one station and will not respond to buttons.
all you need to do is buy a control board its a 15 dollar part try shop jimmy .com
Mar 03, 2008 | iLO 2600 Television
How do shift form numbers to letters?
hell ive had a blackberry phone of ebay it came without a manual i dont know how to make a call or answer one cud you please help
Jan 09, 2008 | i-mate Pocket PC
RCA D52W20 Turns off after a short while
1)Solder any / all bad connects on main/power board +
2) Pull little sister board loosely mounted on one connector =
solder connector pins = re-assemble..............T.
Nov 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDLP50W151 50" Rear Projection HDTV Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
