Question about Echo Garden
Echo pb 265L won't go to full speed I've changed the spark plug I've been told it could be the gas filter?
  • 31 Answers
SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
Posted on Sep 23, 2009
#1 Taper
  • 1040 Answers
SOURCE: ho spark on a pb 403t backpack blower
Well obviously you need to check the spark plug for fire. Try the old one first, then a new one. If you still don't have fire, then you probably burnt out the coil.
Jim
Posted on Nov 30, 2009
  • 85 Answers
SOURCE: echo pb-251 blower runs but cant reach full
may need to adjust high and low jets
Posted on Jan 27, 2011
2strokeJim
  • 577 Answers
SOURCE: my echo pb-2601 leafblower wont start
Did it just quit or you shut it off and won't re=start? Does fuel fill your primer bulb when you pump it ? spray some Carb cleaner NOT STARTING FLUID ! into carb throat and see if it fires,if it does than it's usually a carb problem, and also depending on what you did on your carb clean your needle valve which is neopreme and doesen't like carb cleaner it swells up and won't let fuel through, what I usually do is remove the needle and wipe the tip with clean rag and then clean body of carb with everything out of it then replace the needle and check setting and make sure diaphrams are in good shape not allstretched out or stiff, also make sure the little flaps on fuel pump diaph,seal to the little holes and are soft and pliable, also there is a screen on opposite side of needle, make sure this is clean. Like I said previously see if it will fire on carb cleaner, if so go to the carb. if this is all good then check exhaust port for beeing plugged or the muffler screen being plugged this usually only causes the machine to not accelerate if these are plugged, but will usually still start but just bog. good luck and let me know how you make out.If you have spark and fuel your comp could low or your crank seals may be bad not letting it **** fuel into intake.
Posted on Nov 13, 2011
hunter19_46m
  • 7482 Answers
SOURCE: echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
You still have problems in the carb highspeed circuit..some debris in the passages...
BE SURE TO USE COMPRESSED AIR TO BLOW OUT THE CARB.
(be sure to watch the inlet valve seat, you can loose it and not even know it) Blow the carb clean in a box or something that will contain any part that may be expelled during cleaning.
Please take time to rate me
Bud
Posted on Apr 02, 2013
Won't start. I see no spark. Started 2 weeks ago
check the ignition wiring from the switch to the, ignition module and plug, use a volt meter to check the circuit. If all ok, look towards the ignition module fault.
Mar 26, 2016 | Echo Power Blower PB-265L
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
Echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
Bud
Mar 31, 2013 | Echo Garden
My echo pb265l doesn't start
first check for spark when it first dies then see if its getting fuel start there
Apr 18, 2012 | Garden
Brand new echo pb-251 blower, used it 3 times for 5 minutes each time and it worked perfectly, now the fourth time using it the engine starts easy and idles but engine sputters and misses when pressing...
you can thank the EPA for your blower problem the EPA makes all brands of lawn equipent "tamper proof" with plugs and limit caps. not just echo......when we service an echo piece of equipment we let it "break" in and adj the carb as needed BEFORE it leaves my shop. dont hesitate to bring it back to the dealer, if they are reputable, they will do the adj while you wait......hope this helps. good luck
Nov 21, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo pb-413 leaf blower not running properly
It doesn't appear to be getting enough fuel. Unscrew the "L" and"H" screws about an 1/8 to 1/4 turn. Also at the end of the season run it completely out of gas and you shouldn't have anymore carb problems.
Please rate if this helps-
Mar 23, 2009 | Garden
Garden Logo
193 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
