Question about GE Dishwashers
Ocassionally water will pour from the lower side of the door while washing
  • 46 Answers
Its either the seal on the door.. or if it is soapy discharge you are using the wrong kind of soap...
Posted on May 30, 2008
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
The items in the dishwasher are feeling "gritty" and are not clean at the end of the wash cycle
Remove the filter from the lower front section of the wash tub and clean it out.
Then start a wash cycle with no dishes and no soap.
Once the water fills and starts washing,open the door and pour 1 quart of white vinegar in the wash tub.
Close the door to resume the wash cycle.
Let the machine run a complete cycle to the end to help clean out the water ports.
Jan 06, 2011 | Bosch Dishwashers
Dishwasher soap still in door after wash cycle, so dishes are not very clean. Soap dispenser cover is sprung open but soap (on both sides, wash and prewash) is still mostly where it was poured, only now...
Check for the right amount of water in tub. In this unit close to the lip of the tub after fill. If water fill is correct check movement of lower spray arm. Other possibilities delayed action of dispenser from defective wax motor. Most probable is wash motor. Start unit after fill and when was starts, open door and see if water is being pushed to the top rack and dripping from the top of tub. Motor is easy to install.
Oct 12, 2010 | Maytag MDB7100AWB Dishwasher
Water continually pours out of right side bottom
water continually pours out right side lower vent.dishwasher won't do anything else. no display lights on console.
May 05, 2010 | Viking DFUD042P Built-in Dishwasher
Kenmore model#587(Frigidaire) leaks under door. New install. Had machine for a year plus before install. took off front panel- can see water squirting past lower door gasket as wash arms rotate. cause is...
It does sound like an inner door seal ,however If you get upset at Sears and complain they may help you as they say the squeaky hinge gets the oil..And with Sears the more you squeak the better your chances of results ...Good Luck
Jan 23, 2010 | Dishwashers
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Not making ice
Pour about 2/3 cup of water into icemaker . If it dumps , replace the water valve . If it doesn't , replace the icemaker . Your icemaker may have the white flap arm with a spring attached between the arm and bottom of the icemaker . Check that spring , to make sure both ends are seated . Ocassionally , the top of the spring (fitting into the bottom of the icemaker ) comes out , and has to be pushed back into the hole .
Sep 07, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker no longer making ice
Remove the ice bin and check the spring on the white cut off arm . When arm is pushed back , it should spring back foreward .Ocassionally , the top portion of the spring pops out of the hole which will be visibly evident . If so , use a small screwdriver to push back in place . If looks ok , then pour about 1/2 cup of water into icemaker and wait to see if it dumps . If dumps , then water valve is bad . If doesn't dump , icemaker is bad .
Jul 19, 2009 | GE GSS25LGM Side by Side Refrigerator
Will not do anything
You need to drain the machine manually. Drop the drain hose to a level that is lower than the drain pump and the water will syphon out. Once all the water is out you can open the door. Remove the washing and then close the door and start a rinse cycle. While the machine is taking water, open the dispenser and pour half a cup of milk in with the water. This will neutralise the suds. Once all the suds are gone the washer will be ok.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
