Question about Kenmore Dryers
Timer will run dryer but does not time - Kenmore Dryers
  • Kenmore Master
  • 2,516 Answers
If the dryer has no heat the timer will not move on auto,when the heat shuts off the timer moves,when the heat comes on the timer stops,it will do this until clothes are dry
Posted on Oct 09, 2010
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Dryer does not stop
Hi. this will usually be a defective timer module issue. replacing the timer will fix this issue.
Jul 20, 2009 | Dryers
Short drying time
probably will have to replace timer motor with one that has a longer run time.
Jul 07, 2009 | Maytag MDG16CS Gas Commercial Dryer
Replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
May 01, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Timer
you need volt meter. test voltage to timer motor while running in time dry mode. if 120 volts, replace timer.
Jul 12, 2008 | Frigidaire FGQ332ES Gas Dryer
Error E1
dear customer,
most of the time the timers of dryers aren't faulty even though the dryer doesn't run properly in timmed mode. dryer timers have small motors on the back. The motor rotates gears and cams that open and close switch contacts that control the loads in your dryer. A load is something that does work like a motor, heater, light bulb or end of the cycle buzzer. When the timer is manufactured the amount of time each set of contacts will be closed is built in by the timer cams and gears.so i recommend yu to check the follwoing
  • Test the moisture sensor
  • Test the thermostats
  • Test the heating element
  • and finally the timer device.
hope you find this useful. thank you.
Jul 09, 2008 | Dryers
Dryers Logo
102 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
