Question about Hobby Zone Hobbyzone Super Cub Propeller Rc Airplane
How do I remove the spinner and propeller from the rtf super cub
3 Suggested Answers
SOURCE: how do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Posted on Jul 29, 2009
SOURCE: Just got plane (Super Cub) and flew twice with a
356387029554350
Posted on Sep 15, 2009
Elevator on tail will not move after accident
EITHER YOUR ELEVATOR CONTROL CABLE IS BENT OR MISSING, OR THE ELEVATOR ACTUATOR SERVO IS NOT FUNCTIONING
NOTE:**** CHECK ALL OPERATIONS BEFORE TAKING TO THE AIR AGAIN...IT GETS COSTLY!!!
Jul 20, 2013 | Hobby Zone Hobbyzone Super Cub Propeller...
How do I replace the motor for the hobbyzone cub trainer? do I need to braze/solder the connections? How do I break the current connections?
there are some motor mounts offered for super cub which will fit exactly the holes on the nose of the plane just google it. There is a kit offered on ebay with esc and receiver. I believe 1000 kv would be enough for the plane especially with the floats it might need more power although the bigger propeller that comes with the floats would be sufficient. Personally I would change the motor only if necessary, although my receiver broke and I think i will change everything on the inside. hope to have answered your questions partly
Oct 23, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
Can someone tell me how to replace a broken prop for the super cub? Thanks David
Pull spinner off by placing finger tips under lower edge of spinner between where prop comes out and pulling straight off. The spinner on tight so it takes quite a bit of pressure. The plastic is quite strong so don't worry about breaking it.
Aug 18, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
I assembled my new Super Cub RC plane and when I put the battery in the plane the elevstor snd rudder would move, but when I pushed the throttle up it didnt work. I am new to this and troubleshot it many...
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
Jul 21, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
My fuselage broke in two at the fire wall. can it be glued and if so, how?
you can use an epoxy that is just for foam purposes. But mine broke at the center under the wing. I used colored duct tape to match and it flys just fine.
Jan 16, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
The super cub will not turn off after inserting the battery
If you mean the throttle is stuck at full all the time. Bad news! All electric airplanes can be prone to feedback into the electronics. If the prop stops suddenly when you are under power, the current meant for the motor will feedback into the power mosfet and switching diode. Unfortunately when that mosfet blows, it usually fails in the full on position. Time for a new receiver or a soldering iron.
Jul 27, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
How do we replace propeller on super cub?
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
Hobby Zone Hobbyzone Super Cub Propeller Rc Airplane Logo
365 people viewed this question
Top Hobby Zone Toys Experts
MeAndMyBrain
Level 1 Expert
ZTW Official
ZTW Official
Level 1 Expert
Are you a Hobby Zone Toy Expert? Answer questions, earn points and help others
