Question about HP Photosmart D7160 InkJet Printer
Have an HP Photosmart C6180. New cartridges but get Ink System Failure code OXc18a0306. HELP
  • 1 more comment
  • karol_928 Oct 09, 2010
    Neither worked.
    still didn't work. The ink system failure comes up the minute you turn it on. I know it was hardly used by my friend, so guess I will have to contact hp. Thanks for your input.
    Karol
    did the one with the # and 6 and it is working. Thank you
  • HP Master
  • 4,737 Answers
First try this :
  • Press the On button to turn the all-in-one off.
  • Unplug the power cord from the back of the all-in-one.
  • Remove all the ink cartridges.
  • Wait two minutes.
  • Plug the power cord into the back of the all-in-one.
  • Press the On button to turn the all-in-one on.
  • Install the ink cartridges when prompted.
Now check if the error persists or not.
If the error message still shows on the lcd, then try resetting the printer:
  • Use the On button to turn on the product.
  • Remove the power cord from the product.
  • Press and hold the # and 6 buttons.
  • While holding the buttons down, connect the power cord to the product.
  • Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons. Use the On button to turn on the product. The reset information appears on the color graphics display.
Sometimes cleaning the whole printer component including the paper passage, cartridges' gold contacts, moving the carriage, etc...fix this issue. If you still need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 08, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 09, 2010
    Then try this...
    Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone /spirit.
    While the cartridges are kept for drying, do the following:
    Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn off the mains switch which the dc adapter is plugged in. After keeping it Off for about 5 minutes, turn on the printer again with only the power cord connected, keep tapping the cancel button while it boots up and again leave it On for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges. Check the status message. It should work fine now.
    (Note: press the Cancel button while you install the cartridge/s)
    If the problem persists, there must be internal hardware/firmware problem and will be needed to call for service.
    Good luck.
.photosmart c6180 ink system has failed unable to copy recieve fax or printerror 0xc18a001
As always I start with the dreaded question. Did you use a refilled cartridge in your printer? If so, remove it and install a new HP cartridge. Recycled cartridges are famous for this type of failure. By the way the error code is a Windows error code. If you haven't found a solution to the " ink system failure " yet, it is quite easy to reset (using the buttons) on HP C7180. You can find the reset instructions on my website: http://www.inkbank.com.au/webcontent21.htm
Try this:
May 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
Plz provide the exact error message
Mar 22, 2014 | HP Photosmart C6180 All-In-One InkJet...
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0401 ink system failure error on hp C6180 printer
Check out this link.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Apr 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 - Ink System Failure. Error Oxc18a0306
Try updating your drivers first:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
343 people viewed this question
Seeker5211
Seeker5211
