Question about Whirlpool SB160PEE Gas Single Oven
Kenmore 665.72012103 gas oven bake pre heats OK but does not stay hot. Broiler and stove tops works fine. Replaced oven burner assy #8190618 but still have same problem.
SOURCE: sf195lehz5 free standing gas oven,
This oven has only one gas valve, that supplys the top burners that i never had a problem with.
The bottom oven burner with it's own ignitor, and the top broiler with it's own ignitor. so i can't see replacing both ignitors.Don't think both ignitor could stop working at the same time then work the next time we use the oven/broiler again with their own ignitor. I'll ohm out the temp sensor. but I never saw one work most of the time then stop working. And then start working again. any other pointers.
Thank B.K.
Posted on Nov 01, 2008
huuum
  • 750 Answers
SOURCE: Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
  • 464 Answers
SOURCE: I have an older whirlpool free-standing gas range
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Posted on Oct 15, 2009
SOURCE: the broiler works but the bake option doesn't
Check the bake ignitor (glow bar attached to the burner). If it does not glow at all, but the voltage is supplied to it - replace. If it does glow, but draws current less than 3A - replace.
Posted on Oct 16, 2009
  • 3 Answers
SOURCE: My oven broiler does not seem to be working
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Posted on Dec 12, 2009
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Kenmore gas oven model 91136519 from 1992 . The stove top burner work as well as the oven broiler. But the bake mode of the oven will not come on. What could be the problem?
Faulty temp. control...The variable temperature portion is faulty, but broiler function FULL ON GAS is ok...Replace the Temp control assembly.
Jul 01, 2010 | Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
24: gas oven 30425
you will need to replace that bake ignitor which comes as an assembly with the burner bar, it is part number 8190618 .this will cost u $50.00.   That should solve it. rate the solution if it hels u. feel free for further assistance. thanks
Nov 10, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kemore Gas oven - trouble igniting
Hi Deeg, there was a service flash regarding this problem. The bake burner and bake igniter have been modified to assure consistent oven ignition and performance. The number of ports on the burner have increased located at the electrode tip. The electrode shield has also been modified. This repair should be covered under warranty. The kit part number is 8190618 for your information. If your serial number ranges from RK01 through RR11, this is your problem. I would call Sears and request service. Catriver.
Sep 12, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Whirlpool SB160PEE Gas Single Oven Logo
52 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
