Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I have a konica Minolta bizhub C250 and the screen is reading "replace transfer unit" and "replace fusing unit". I contacted a local repair guy that said he might be able to reset the counters and the machine should continue to work. Then he called back and said the new machines IE: Konica Minolta Bizhub C250 could not be reset and the counters are actually a microchip in the fusing unit and transfer unit. Is there any way to reset the counters and can you give me some direction?
  • 1,110 Answers
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Posted on Oct 08, 2010
  • 8 Answers
The Fusing unit can be reset.Open the front door and remove 2 blue connectors,If your machine has a finisher sorter slide it to the left look where the paper would exit and to the back 1 screw to remove ,the unplug the other connector.Open the right side remove 2
screws.Now where the white connector look for a green 1/4 amp pico fuse it has shroud raped around it.replace the the part the fusinig unit will reset
Posted on Nov 07, 2010
My Konica Minolta bizhub C250 says replace transfer unit. I have looked for this part and can find nothing listed as a Transfer Unit. There are many parts listed but none specifically says Transfer Unit....
I am sending you this link because A) they have all the parts listed including part numbers and pictures. They are also a good source for parts and supplies. You might find one cheaper on the net tho. Also keep in mind that these transfer belt units are resettable by replacing a $5 fuse in the unit. If you have a local independant repair guy, maybe he can research this and reset your existing unit as they will usually go at least 2 cycles. I reset a dozen or more of these units per year for my customers.
http://www.precisionroller.com/search.php?q=minolta+c250+transfer+
WheatlandServices
Jan 25, 2011 | Konica Minolta bizhub C250 All-In-One...
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
A new installation is not detected when a new
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Can i reset my Konica Minolta C250 transfer unit and fusing unit?? Is there a chip reset that I can buy for the transfer unit and fusing unit? I just purchsed the resets for the image units and they worked...
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Sep 30, 2009 | Konica Minolta bizhub C250 All-In-One...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,479 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
