Casio fx 992s when i try to do simple calculations like 1.33360 - 1.33041.....the answer is 3.19 and other little numbers in the top right. i dont get this or like this. i want a proper 5 decimal answer. for forex trading calculations. ive tried all the settings, i have no idea what they mean, like gra, comp, sd, lr, cmplx, deg, rad, gra, fix, sci, norm, base n. can someone please help? thankyou
  • ballykida Oct 09, 2010
    yes this works i think, but when you do 5 decimal setting like this, when doing normal smaller calculations, it shows 5 decimals, not ideal, another thread here says mode>norm 3> then number 2 or number 1, sorts it out, where little calculations are normal, and 5 decimal calculations show accordingly with no short cut answers. ok thankyou all. great site!
    President:
  • 2,992 Answers
It sounds like you need a manual for your calculator. You can download a scanned copy here, and it will explain what all the keys are for. For now, here is the way to set the calculator for a five decimal place display:
  1. Press the MODE key three times. A menu offering choices of FIX, SCI or NORM will appear.
  2. Press the 1 key to select FIX mode. The message "0~9?" will appear.
  3. Press the 5 key. This tells the calculator to display five digits after the decimal.
This mode setting will hold until you change it to something else, or when you turn off the calculator.
Spend some time reading the manual and work with the calculator. It's a powerful tool with a lot of capabilities. Thanks for using Fixya!
Posted on Oct 08, 2010
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
Jan 03, 2016 | Casio FX-9750GII Graphing Calculator
Hi I have Casio fx -991es plus calculator its give me wrong answer in complex number equations
It does not solve complex number equations. You can do simple calculations on complex numbers: addition, multiplication, etc. But nothing fancy.
Oct 26, 2015 | Casio Office Equipment & Supplies
How to make my degree button work?
I am sorry but the image does not show any Degree button.
To set the angle unit you have to press the Mode button twice before you arrive at the angle unit configuration. See the screen capture below.
Jan 16, 2014 | Casio Fx-992s Scientific Calculator
How do i make the degree button of my fx992s work?
On my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
Oct 31, 2012 | Office Equipment & Supplies
How and key to inverse
Look for a key marked [x^-1] or [1/x]. The marking may be on the key or on the face of the calculator. In the latter case you will have to press the SHIFT key first. Before you can calculate the reciprocal of a number the number must be entered.
Oct 23, 2012 | Casio Fx-992s Scientific Calculator
I dont know how to find the square root on my casio fx-300ES scientific calculator problem it wont let me square root 42 , when i square root 42 , 42 keeps coming and not the answer
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Sep 07, 2011 | Casio fx-300ES Calculator
My casio fx-992s is showing fix and deg on the screen. I think the "fix" is causing me a problem but I can't get rid of it. All my decimals are being rounded up to whole numbers! Thanks
The DEG is merely indicating that the angular mode is set to degrees. If you want to change it to radians or grads, press SHIFT MODE and make your selection.
Likewise, the FIX is merely indicating that the calculator is displaying numbers in fixed decimal notation. If you're not seeing any digits to the right of the decimal point, then you're in FIX 0 mode. To change it, press SHIFT MODE. You can choose FIX and the calculator will prompt for the number of digits, or you can select NORM.
Nov 29, 2010 | Casio Office Equipment & Supplies
I need help with this casio caculator
If you mean to do x power y, so you must have an ^ button or y with little x(top right) this is the power. And when you want negative power like -2 so input 2 then "+/-" button (it's change the sign of the number).
Jul 06, 2009 | Casio FX-115ES Scientific Calculator
User's guide
You can download the manual from the manufacturer's web site at
http://support.casio.com/manualfile.php?rgn=1&cid=004001016
Nov 21, 2008 | Casio FX-300W Plus Calculator
921 people viewed this question
k24674
jasbo
jasbo
