Question about GE Tritonr XL GSD6260JCC Dishwasher
Water will not drain out of the bottom of dishwahser
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
Whirlpool dishwahser Green clean light flashing/ will not work
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Oct 19, 2011 | Dishwashers
Water do not flow into the dishwahser
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Apr 15, 2011 | Dishwashers
Hi The dishwahser does not clean properly. There does not seem to be enough water coming through. I have cleaned out the pump and filters but this has not resolved the problem. Getting a knocking noise as...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Please post back for any further assistance.
Daniel
Aug 13, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
The water does not fully drain out of the dishwahser
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Aug 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Detergent (gel) always left in dispenser and on bottom of door
Get package of unsweetened limonade drink mix and put in machine and run a cycle, this will clean all parts of hard water deposits. Cascade powder is the manufactors choice, till they get ad space and samle giveaways
Mar 12, 2009 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Dishwahser not washing and draining properly
Need more info. Model # Properly?
Mar 27, 2008 | Dishwashers
Help with how to use properly a dishwahser.
You either have a blocked drain or pump or check to see if the water tap is turned on. It means that either the water wont pump out or fill with water. Good luck
Sep 27, 2007 | Miele Advanta G2020 Dishwasher
Broken dishwahser
Check to see if there is a waste basin at the bottom of your dishwasher. Some models have them and they require regular maintenance / cleaning every 6 months or so. If one does not exist, try to purchase one of the JetDry Dishwasher cleaner and set your dishwasher to run at its hottest (usually "pots and pans" or "extra hot") for about 2 cycles. That should clean the drain of the large food particles that have accumulated in the dishwasher drainage. Should the above not provide satisfactory results, you may want to try a VERY SMALL AMOUNT of drain cleaner in the middle of an empty cycle to try and remove the debris. (CAUTION: too much drain cleaner will damage the waste bin if not rinsed properly and render your dishwasher useless..please only do this at your own risk)
Jul 24, 2007 | Whirlpool 24 in. ADG6340 Built-in...
INDESIT DISHWAHSER DG5100W
If it does not fill properly to a certain level, the heater will NOT come on, so you need to solve the filling problem. Is the drain hose raised sufficiently? Is the pressure hose blocked? Does it let water in and then just stop? Oshie
Jun 26, 2007 | Indesit 24 in. D61 Free-standing...
GE Tritonr XL GSD6260JCC Dishwasher Logo
685 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
