Question about Intermatic E1010 - 24 Hr. Dial - Heavy Duty In-Wall Mechanical Time Switch
I have an intermatic E1000 24 hr in-wall mechanical time sswitch that now has a very loud ticking. Is there some remedy other than repplacing it.
Intermatic timer instructions
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T101%20Instructions.ashx
Aug 01, 2014 | Intermatic T101 - 24 Hr. Dial Time Switch...
Does this timer make any ticking or loud noises??
Every mechanical device makes some noise.
Plug-in timers generally are NOT noisy because the switch and trippers are plastic.
Direct-wire timers that are made of metal are noisy when the switch clicks on-off.
Feb 18, 2011 | Heavy Duty INTERMATIC 6 Outlet Outdoor...
When setting the timer (model 12-817) power is activated between the hour choices (2 hr, 4 hr etc) but the power goes off when the dial is turned to the actual hour selection. If left between the hour...
What timer is this?
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Sounds like a defective timer.
I have three Intermatic spring wound timers that are used every day, and never have that problem.
After all, how does the timer 'know' when it's set on the 'hour' since the dial does not have stop points at specific times?
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic FD60MH Energy Controls -...
How do I reset the time needle on my intermatic modle t101 The screw was loose and the needle move so
T101 Intermatic is 120Volt electro-mechanical timer
Silver pointer is located at 6:00 position.
Tighten the center screw with star screwdriver
Lift and rotate yellow dial until current time lines up with silver pointer.
How electro-mechanical timers work:
Place ON-OFF trippers on dial.
Trippers rotate around with passing time.
Trippers encounter on-off lever.
OFF tripper clicks lever one direction.
ON tripper clicks lever other direction.
Manual override lever clicks back and forth each time on-off lever is clicked.
How to wire T101:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 16, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
I can turn the timer off and on and my outside lights work. However, the clock has stopped ticking and therefore not working.
The clock mechanism is replaceable. You can buy it at Lowes, Home Depot, or Ace Hardware. Im sure you can also find them online.
Oct 18, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
The ticking of the timer is so loud and can be heard on the other side of the wall inside the house. Is there any way to quiet the timer or do I need to just disconnect the whole thing to get rid of the...
Try mounting on rubber standoffs. The mechanical timers are noisy and when mounted on a wall that amplifies the noisy.
As a test, un bolt it from the wall and see if noise is acceptable. If so, find a cushioned mount.
Sep 22, 2009 | Intermatic WH40 - Water Heater Time Switch...
Instructions on how to program the Intermatic EJ351C
take a look at this :
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
-or -
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
hope this helps
Jun 03, 2009 | Intermatic Programmable 24 Wall Switch...
Intermatic E1010 - 24 Hr. Dial - Heavy Duty In-Wall Mechanical Time Switch Logo
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
