Question about Troy Bilt 5.5hp Self Propelled Mower
Should i use oil with or without detergents in it? i found 30wt of both.
  • 27 Answers
With a typical mower engine, detergent oils are the way to go. Usually non-detergent oils are for special applications such as air compressor pumps, which specifically call for non-detergent oils. Check you engine, if it is an overhead valve (OHV), then you will want to use a multi-viscosity oil (5W-30), but if it is not, then use the straight 30W.
Posted on Oct 08, 2010
What kind of oil goes into the shaker
30wt non detergent
industrialpaintmachinery.com
Mar 03, 2015 | Red Devil 5400 Heavy Duty Paint Mixer
What type of oil for XL honda motor with Cat pump
the motor 30wt oil or 10- 30wt, the pump takes pump oil or 30wt
non-detergent, so the answer is no they don't take the same
Sep 14, 2014 | Honda Garden
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Jul 02, 2011 | Garden
What type of oil and gasoline do you nee d to run Craftsman 6.5 lawn mower?
generally all 4-cycle lawn mower engines are tuned to use regular unleaded gas ,(I personally use mid or high grade unleaded)....and for engine oil use strait 30 WT engine oil...... I often put a dash of fuel system cleaner in each gallon of lawn mower gas,it is not absolutely neccessary but seems to help moisture stay out of gas..(DO NOT USE HEET or other methenol based fuel additives for this can cause overheating or scoring of piston and cylinder...but rather use a petroleum based additive,this allows the small amounts of moisture in fuel to pass through the carbeurator without clogging filters or fuel system for smoother running)..also...if you put lawn mower up for winter it is always helpful to use a fuel stabilizer such as "STABIL" or other such products (follow directions for use) and be sure to change the crank case oil in the spring before using....this will give you much longer life from your lawn mower...
Keep air filter clean!!!..... Happy mowing!!!....so, the answer?...regular unleaded and 30wt engine oil...if you would like..they have special engine oil for 4-stroke engines at most hardware and walmarts n such...but is just expensive 30wt oil... Enjoy your day,Todd
Nov 23, 2010 | Garden
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
Oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Troy Bilt 5.5hp Self Propelled Mower Logo
117 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
