Question about Bissell 3522 PowerForce Bagged Upright Vacuum
How do I change the belt? Do I have to twist the belt.
  • 377 Answers
You do not have to "twist" the belt.
You should be able to find your answer at this URL:
http://www.bissell.com/product_search.aspx?searchType=main&searchtext=3522
Look at the users guide for information on changing the belt. I would suggest that while you are changing the belt, also take time to clean the beater brush, you have to remove it anyway to change the belt. Clean the brush as best you can and add some WD40 to both ends between the brush and the small plastic pieces that hold it in place with the vacuum.
Posted on Oct 08, 2010
  • pwillitz Oct 08, 2010
    If you find my solution to be of help to you I would appreciate a Thumbs Up rating from you.
    Thank you.
    Paul
  • pwillitz Oct 09, 2010
    I am very sorry my efforts did not prove of help to you.
    Paul
Drive brush roller spinning in reverse, not picking up
someone changed the belt and didn't put the twist in proper direction
Feb 07, 2015 | Riccar Vacuums
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
Gl1109 hoover globe twist and steer
How do I change the belt on my hoover twist and steer
Dec 25, 2013 | Vacuums
When changing the belt does it need a twist
no, it needs to be taught between the two rods but if it is twisted it will break.
Oct 24, 2013 | Vacuums
I can't get the screws out to replace the belt on my carpt shampooer...
No screws need to be taken out on a Kirby for a belt change. Take the nozzle off, remove the base plate with the 2 twist locks, pull the brushroll out. Puton the new belt, and re-assemble. Twist the belt lifter around the belt, replace the nozzle, spin the belt lifter back, and go vacuum
Oct 11, 2013 | Kirby Heritage II Vacuum
Kirby Generation 3 Model G3D
Look through THIS article. If you cannot twist the know - you need to take it apart and lubricate.
Rocky
Sep 04, 2009 | Kirby G4 Bagged Upright Vacuum
I can't turn the belt off of my Kirby vacuum. I had the front off of it earlier to attach the hose, but now when I put the front back on, I can't get the belt to turn off. The lever twists about 3/4 of the...
turn the front part to the green so it is level and then twist the front to the red make sure the belt catch the hook as you twist it then if the belt is hooked just put it back on the vac like normal and lock it in place then twist it back to the green go postion
Aug 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I can't change the belt on my Ultimate G Diamond Edition
You have to take the nozzle off. Then twist the handle to OFF position to catch and stretch the belt, put the nozzle back and then twist the knob to ON.
Instructions with pictures HERE
There is video manual on the front page on goodvac.com too...
Good Luck,
Rocky
Mar 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you change the belt on a kirby sentia vacuum cleaner?
ok Imussati here is how you change the belt take the roller brush out and put the belt in the center of the roller brush place the roller brush back in nowtake the name plate and twist it until the hook graps the belt it may seem like it is to tight but keep turning it once you get the belt twisted to the highest point put the nozzle back on the vacuum and lock it down then turn the face plate back the way it was and it should allow the belt to slip around the driveshaft and you are ready to roll. hope this helps
Jan 24, 2009 | Vacuums
Hi I have an electrolux "The Boss" hand held vaccum cleaner. I cannot find the instructions and am having problems changing the belt. It is model number Z57A. Product Number 900-250-006. It...
You need top lace belt on brush roller and re[-assemble by putting plastic cover on which is retained by 2 recessed philips screws.. Prize off triangular coverat fornt.behing that you should see the belt lying loose.You need to get a blunt object to twist and push belt ovet the motor shaft. You may get it on in wrong direction and if you do,loosen off belt and twist the other way.
Jul 12, 2008 | Electrolux Vacuums
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
429 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
