Question about RCA Lyra RD1072 MP3 Player
When i try to transfer files to my device i get a message that says it is "write protected" and i cannot transfer files. how do i turn off this "write protection"
    Sergeant:
  • 270 Answers
According to your manual, you device does NOT have a write protect feature.
Get your manual here:
http://www.retrevo.com/d/ds/progress?doc=8093d57f74f10c7ac0fed7aecc49455f&rk=0.03367205450935784
HOWEVER, the data card does. While holding the data card with the metal showing on the botton towards you, on the left edge, there is a "write protect" tab.
change the position of this slide switch, then re-insert into the RCA device. It should no longer be locked.
Good luck, and don't forget to vote.
Posted on Oct 08, 2010
Coputer to memory card not copy song
reachbhimraj
Most likely the file you are trying to copy is a copy protected and/or not supported by the device that you are trying to copy the file to.
To know if the file is protected your can right click on the file and select properties. Then under the summary tab you should see an option if it is protected or not.
If the file is not protected let me know the format of the file and the make and model of the device that you are trying to transfer the files too.
Issken
http://www.fixya.com/users/issken
Sep 29, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
In trying to save a file to my flash drive, I get
I did not fix the problem but was able to transfer the files on it to another flash drive.
Dec 05, 2009 | iLO (2 GB) MP3 Player
Transfer WMA files to Sansa c250
There two types of WMA file - protected and unprotected (also called "DRM-free" and "DRM-encrypted"). Some protected or encrypted WMA's may allow you to play back on your computer, but will not allow you to play those same files on an mp3 player. There are only two ways around your problem - one is expesnive, and one is illegal:
1) You can purchase additional rights on Overdrive to transfer your audiobooks to a "portable device" (by which, they include mp3 players).
2) You can download a program such as Tunebite to strip the Overdrive of it's DRM license, rendering the file of its protection (I would NOT reccomend this route).
The WMA files that you had that worked before were either unprotected, or were protected but had transfer rights.
-Tha Mp3 Doctor
Mar 19, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can not transfer wma,wmv
The exact description of that error message is: "The file could not be transferred because the device clock is not set."; NS_E_DRM_LIC_NEEDS_DEVICE_CLOCK_SET
It is related to a DRM license that is on the videos that you are trying to transfer - either the video you are trying to transfer has a DRM license that does not have transfer rights, or does not allow reencoding.
Basically, the video you are trying to convert is copyright-protected, so you will not be able to use it on a GoGear, only because the GoGear's require re-encoding first. Sorry.
The only solution is illegal - you would have to use a DRM-Stripper such as Tunebite to remove the license from the video. I would not recommend it.
-Tha Mp3 Doctor
Feb 28, 2009 | Philips GOGEAR SA6045 MP3 Player
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Removing write protection from Flash pen drive
try this
1) In My Computer, right click on the drive letter of your pendrive and
2) Eject it.
3) Then pull the card out and stick it back in.
4) Try to write to the card. If it works, GREAT!
5) If it DIDN'T work, repeat steps 1 through 4.
or this software
http://www.apacer.com/en/support/downloads/HS2.0_Utility_LFormat.zip
or this
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
visit us for more info http://gilablog.com
May 12, 2008 | BUSlink MUSICA MP3-PBD1G MP3 Player
My Philips SA21X
The device itself is not faulty. This is Microsoft's fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA6025 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
There are a few possible answers:
1)Start simple - disconnect the GoGear from the computer - let it update - then reconnect it to the computer; if this fails, restart your computer and try syncing again
2)You need a firmware upgrade to make the device compatible with your computer: just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the update tab
3) The songs have Digital Rights Management (DRM) protection.Try re-downloading the songs without DRM protection.
4) The songs are in a format not recognized by the GoGear. The GoGear, for instance, will not take iTunes files b/c they are AAC format. With MP3 files, the player supports 32 –320kbps. With WMA: 5-192kbps with sampling rate 8.0kHz up to 44.1kHz. Right click the song file, and select "Save As", and then change the format of the song file. Or, redonwload, in the above-said format.
-Tha Mp3 Doctor
Jan 25, 2008 | Philips SA4010 MP3 Player
Trying to play my music which I have transfered from CD to my phillips MP3 player and it says File format not supported.
The device itself is not faulty. This is Microsoft's1.gif fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA6025 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
-Tha Mp3 Doctor
Dec 30, 2007 | Philips GoGear SA261 MP3 Player
M p 3 player
Instruction manual can be found by entering your model number at www.usasupport.philips.com
-Tha Mp3 Doctor
Dec 26, 2007 | Philips GoGear SA261 MP3 Player
Error Message when Sync-ing to Philips sa3125/02
your player does not support any protected files, Protected files transferred to the player will be skipped without playing.
whats the error you get?
Dec 07, 2007 | Philips SA3125\02 MP3 Player
RCA Lyra RD1072 MP3 Player Logo
101 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
