Question about Whirlpool Refrigerators
ED5LHAXMQ00 I have the subject model and the water delivery to the drinking water and icemaker stopped working. The water supply is to the fridge is okay. I would like to obtain a diagram so I can troubleshoot the problem. Can you provide a PDF file of the water control and delivery system? Thanks, Frank Stelloh N5302 Nancy Lane Iron Ridge, WI 53035 (920) 625-3211 klystron2007@netzero.net
    Scholar:
  • 110 Answers
GO TO WWW.SERVICEMATTERS.COM WHICH WILL GIVE YOU ASSESS TO ALL WP, AND MAYTAG JOB AIDS
Posted on May 30, 2008
Icemaker stopped working. There is water to the refrigerator (is water to drink) but does not fill icemaker. Thanks, Gene
I changed the water inlet valve on the fridge. It still doesnt send water to the ice maker, but continues to send water to the door, so what do i do now?
Oct 15, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
No water to icemaker.
check the solenoid on the back of the fridge where the water line is hooked into it. one solenoid is for water the other is for ice this is usually the problem with the icemaker.
Jul 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not filling with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 01, 2009 | Maytag MZD2669KE Side by Side Refrigerator
Icemaker wont dispense water. worked last night but not today.
without knowing model #, i would check to see if the unit has a resevior for drinking water in the fridge side, could be something as simple as the temp set too low in fridge side and freezing the res. check that out. or it could be that your water valve in the back is faulty. take the hose off in back and have someone push the dispenser lever in the front. if it squirts your valve is good and you probably have somekind of blockage in the plastic tubing somewhere. solid 12 gauge wire works great for that. just run it in the tubing but be careful, you dont want to damage it. good luck.
Mar 20, 2009 | GE Refrigerators
Icemaker not working
mike you might have a frozen fill tube check for that also are you getting wtr ook at the dispencer if you dont recheck water supply again
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Stop working
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
245 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
