Question about Car Audio & Video
I bought a VR3 roadaster car radio with the dvd player. is there anyway to bypass the brake wire so dvd plays anytime
  • 11,800 Answers
Yes, it can be done: all you need to do is to connect the handbrake wire to the ground and the speedo sensor to 12 v. But i must warn you that this is illegal and severely punished - huge fines.
Posted on Oct 08, 2010
Is there any way to bypass hooking up the e-brake wire for the vr3 Roadaster car stereo
To get passed the brake issue there should be a lose/bear end wire at the back of the head unit - just attach it some how to the metal head unit cage, this should hopefully bypass the problem
Hope This Helps
Pindy92
Oct 08, 2010 | Virtual Reality Sound VR3 CD Player w/ USB...
How do i bypass the parking brake switch in order for my video to play
I think the wire that should go to your hand brake is green, all you need to do to bypass this is hook it to an earth.
May 06, 2009 | Clarion MAX385VD Car DVD Player
Bypass parking brake for VR3
Hi, I had the same prob with mine. Pretty easy fixed. There is an earth wire connected to the park brake switch, you have to disconnect it. If you are not savvy with car stereo installation, I would advise you take it to strathfield or another car stereo installer - it is a quick and easy job and they shouldnt charge you more than 20 bucks for it.... if that. Beware though, playing movies in your field of view is VERY distracting and dangerous..... and illegal.
Jan 16, 2009 | Jensen VM9510 Car DVD Player
VR3 VRVD630 dvd bypass instructions/codes
I also just bought a VR3 DVD -CD PLAYER MODEL# VRVD630 ALL I DID WAS CONNECT THE BROWN PARKING BREAK WIRE TO THE GROUND WIRE THAT LETS YOU WATCH DVD WHILE DRIVING HOPE THIS HELPS
GOOD LUCK STROUP
Nov 27, 2008 | Jensen VM9510 Car DVD Player
ITS just a ground cable hook it to the radio ground i did and mine works fine
Aug 21, 2008 | Jensen's VM9312 Car DVD Player
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jun 25, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
Ground the handbrake wire to the outerpart of the "line out" connector if it's not in use, works a treat
Apr 29, 2008 | JVC KD-AVX11 Car DVD Player
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
Parking brake switch?
the best way to bypass is to connect your green handbrake cable to ur black power cable then it will work. it only needs power getting to it for it 2 sensor the handbrake is on.
Oct 22, 2007 | Jensen VM9510 Car DVD Player
HOW TO UNLOCK MY VR3 RADIO TO PLAY DVD MODEL VRVD630
The brown wire labeled parking brake -12v should be connected to the parking brake switch. So that to watch a DVD the parking brake needs to be set. but can be bypassed by connecting to ground.
if connected to the lights it could be your problem
nels
Oct 16, 2007 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
