Question about Vacuums
Adding hampton bay light model #430-727 to ceiling fan. ceiling fan works but lights dont work. connected white to white wire & black to black wire. what else can we try?????
  • 14 Answers
SOURCE: Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Posted on Jun 07, 2010
  • 377 Answers
SOURCE: My Hampton Bay ceiling remote
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Posted on Oct 11, 2010
GodBlessU
  • 3513 Answers
SOURCE: Receiver on Hampton bay the
First you need to check the housing mounted to the ceiling as the transmitter is there. Next you have to try and match it to a new remote or look for some number on the transmitter. However you can usually buy a new remote and transmitter for 30 bucks and just swap out the transmitter. This will be helpful in case you cannot match the numbers. They come labelled and r pretty easy to install. Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 31, 2010
  • 1796 Answers
SOURCE: how do i remove the
HI!!
I assume you've removed the blades. so next step is to check the canopy. The Ceiling Fan canopy has a decorative ring RIGHT against the ceiling that covers some screws. Remove the ring, remove the screws, the fan will come down. You don't have to mess with the motor assembly.
To Install Fan on a different location, you may follow the general instructions below that apply to your model.
General Installation Instructions for most fans:
1. Some pieces of the fan require assembly before hanging. Attach the blades to the blade brackets. In the case of a downrod fan, slip the canopy over the downrod and attach the downrod to the fan. In the case of a close mount (not hugger) fan, attach the canopy directly to the motor. In some cases you may want to attach the light fitter (should one apply) to the motor before assembly, in other cases it will be easier to attach once the fan is on the ceiling. Some fans also require the switch housing be plugged in and attached. In any case, at this point the fan should consist of 3 or 4 types of pieces: the motor assembly, the mounting bracket, the blades, and, if applicable, the light attachments.
2. Attach the mounting bracket to the fan brace and/or ceiling outlet box.
3. Hang the motor assembly from the mounting bracket. In some cases this will be via a small hook, in other cases the ball on the end of the downrod will fit directly in the bracket. Be sure the groove in the ball lines up with the tab in the bracket and/or canopy.
4. Connect the wires. Refer to the Ceiling Fan Wiring Guide for more information.
5. Attach the canopy to the mounting bracket. In the case of some fans this may be 2 thumbscrews on the bottom, others may have as many as four screws on the side. In close-mount fans and some downrod fans the canopy is load bearing, in other cases it is purely decorative. In downrod fans be sure the ball is (still) lined up with the tab in the bracket/canopy. If the canopy has a decorative ring to cover the screws, attach that.
5a. For hugger fans, attach the motor to the mounting bracket, in most cases with four locknuts (some fans may vary). Attach the motor housing cover to the mounting bracket (usually with four screws).
6. Attach the blades to the motor via the blade brackets. Each blade bracket uses two screws which fit directly to the motor or the flywheel.
7. Attach the light fitter, if applicable and if it has not already been attached. Attach the glass to the light kit, and any other decorative accessories the fan may include.
Mount a ceiling box in the location you will install your fan if it is a new installation. For replacing an existing fan, you can use the box already there after removing the old fan.
  • Mark the location for your new fan. Using an electrical box appropriate for ceiling fan installation, trace it's outline on the ceiling with a pencil.
  • Cut the outline of your box out with a keyhole saw.
  • Slide your new box into the hole you have cut until it is flush with the bottom of the ceiling.
  • Support the box with a block of wood nailed solidly into the ceiling joists.
  • Run the appropriate wire, usually #12 MC cable or "Romex".
  • Extend 6 inches of your new cable into the box, and connect the other end to a breaker in your panel box, or an existing circuit above the ceiling.
If you wish to have your ceiling fan controlled by a light switch, you will have additional electrical installation to do for the switch, as well, not covered in the scope of this article.
  1. Turn off the power to the fan. For this step, you will need to locate the electrical panel, find the breaker controlling the circuit the fan is on, and turn the breaker off. Be sure no one turns the breaker on while you are installing the fan.
  2. While power is off, hook the green ground wire on the mounting bracket to the green ground wire in the ceiling. Twist the wires together tightly. As this is the "ground", it will not need insulation.
  3. Slide the mounting bracket up to the ceiling. You should have a mounting plate which attaches to your ceiling box with two screws. These items are provided with the new fan.
  4. Strip 3/4 inch (approximately) of insulation from your white and black power wires in your ceiling box.
  5. Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire. Cap each one with insulated wire nuts, then wrap these with vinyl electrical tape if you desire.
  6. Look to see if your new fan has a down rod,and if so, slide it on the fan housing. Slide the canopy onto it. If it is a "low profile", or ceiling hugger type, loosen washer on canopy.
  7. Slide fan housing up to ceiling and secure the washer onto canopy. Secure fan.
  8. Slide each blade onto each blade bracket until they lock into place.
  9. Insert light bulbs.
  10. Squeeze light holders. Put each light shade onto each light. Let go of light holders. Light shades lock into place.
  11. Secure pull chains onto fan.
  12. Turn power on and test fan.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Jan 19, 2011
GBELECT
  • 23 Answers
SOURCE: I need to replace the
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Posted on Feb 01, 2011
Testimonial: "."
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I have a broken chain switch that will not allow me to use all four light sockets. presently only using two sockets. Question: can I by pass the switch by combining all the black wires from the leading...
The blue should be for the lights and you can ty this into the black. The red should be the incoming for the motor to the fans. Some models are different and I strongly believe you have got to be talking about a ceiling fan and not a vacuum. Is this a test question? Because it is a darn good one if you do not mind me saying so however you might have not noticed to check or uncheck a box for the fans. Good luck.
Nov 02, 2010 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
Oct 11, 2010 | Vacuums
How to remove a Hampton Bay Cameron Plus Blue Ceiling Fan?
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
Aug 29, 2010 | Vacuums
Can I use a regular 2 conductor cord set on a ceiling track lighting kit and plug it into the wall? I Dont have a box in the ceiling
Yes, but make sure to use a polarized male plug ( the one with the slightly larger prong on one side).
Aug 22, 2010 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
Vacuums Logo
179 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
