Question about Fisher and Paykel GWL11 Top Load Washer
How do I remove the drain pump? - Fisher and Paykel GWL11 Top Load Washer
  • 81 Answers
Should push in a bit and then turn counter clockwise
Posted on Oct 08, 2010
I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Jun 24, 2015 | Samsung Washing Machines
Drain water
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
NOT POMPIN WATER OUT.I CAN HEAR POMP GOING BUT NOTHING HAPPENS
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
MY LG WASHING MACHINE SCREEN KEEPS ON SAYING OE
It is a long drain error and appears when the washer is not fully drained after 10 minutes of draining. It can be due to a clogged or kinked drain hose, clogged pump filter, or the pump is not working properly.
LG Front Load Washers Drain Problem Troubleshooting and Repair Guide
  1. Remove the two screws on the back of the top panel securing it to the cabinet.
  2. Slide the top panel to the back of the machine then lift it.
  3. Disconnect the wiring harness connector from the control panel.
  4. Pull the dispenser drawer out and remove the two screws under it.
  5. Lift the left side of the control panel and pull it out.
  6. Remove the four screws holding the top part of the front panel to the cabinet.
  7. Open the pump filter cover and remove the screw holding it.
  8. Insert a flat-bladed screwdriver or a putty knife in the left and right edges of the filter cover then pull it out.
  9. Remove the screw from where the pump filter cover is removed.
  10. Open the door and remove the door gasket retaining hoop by stretching the retainer spring.
  11. Peel off the door gasket into the drum.
  12. Tilt the front panel and remove the door switch wiring harness connector.
  13. Lift and remove the front panel from the cabinet.
  14. Remove the sump drain plug and drain the water in the sump into a shallow pan.
  15. Remove the sump hose from the tub by loosening the clamp holding it.
  16. Remove the drain hose from the drain pump and the recirculation hose from the recirculation pump if there's any.
  17. Remove the two screws holding the pump assembly to the cabinet.
  18. Push the pump assembly in and lift it out of the machine.
  19. Remove the pump filter from the pump housing and check it for any obstruction.
  20. Check the sump and drain hoses for any obstruction.
  21. Remove the drain pump from the housing and check the impeller for any obstruction or damage.
  22. Replace the drain pump if the impeller is damaged or if no obvious obstruction is found in the pump filter, sump hose, or drain hose.
  23. Install the new drain pump and reassemble the other parts in reverse of the disassembly steps above.
Please let me know if you need further assistance regarding this problem.
Jan 23, 2010 | Washing Machines
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Water not pumping out in the spin cycle anymore
Check the drain pump and drain hoses. The drain pump is located in front of the motor. To access it, remove the end caps from the console. Remove the 2 screw holding the console to the cabinet. Pull the bottom of the console toward you slightly and flip the console up. Unplug the lid switch molex connector. Inserting a flat screwdriver from the top and pushing back, remove the brass clips on each side. Open the lid. Holding the inside of the cabinet, tilt it toward you and remove it from the base. This will give you access to everything including the drain pump and the drain hoses. Try to remove as much water as possible from the inside since it will all come out when you remove the drain hoses from the pump (hopefully you are near a drain in the floor). Remove the hose clamps and check the hoses and pump for any obstructions. Chances are, you will find a missing sock.
If it all looks clear, remove the drain pump from the motor and inspect where the pump connects to the motor for a broken connection slot. Replace the drain pump if necessary.
Mar 03, 2009 | Kenmore Washing Machines
Sounds like something stuck in the washing machine when draining
Something has become stuck in the drain pump.
1. Remove the back cover. The drain pump is in the lower left corner.
2. Tilt machine forward for easier access.
3. Unplug the pump motor power plug.
4. Loosen the hose clamp from the tub.
5. Remove the drain hose connection from the pump.
6. Remove the three screws securing the pump to the tub.
7. Remove debris from pump.
8. Replace pump.
9. Merry Christmas...
Dec 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
64 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
