Question about Epic 425 Mx Treadmill EPTL88105 !
My Epic 425mx works fine when my wife uses it, but when i get on to walk it slows to an immediate stop, or won't even get going to full speed. It used to do this only when i would try to run but it has gotten worse. I only weigh 175lbs.
  • 31 Answers
Check the motor belt tension and the walkbelt tension first. If iether is loose the walkbelt will stop.
Posted on Jan 15, 2011
Treadmill- Epic T60. Immediately starts of at full speed and causes circuit breaker to trip
Hi There,
This problem could be a faulty speed sensor . Especially with optical speed sensors. The other reason could be a faulty LCB ( MCB)
Apr 15, 2013 | Icon Epic T60 Folding Treadmill EPTL81804...
What lubricant to use on 425mx..motor seem noisy
Oiling the deck of the treadmill with a silicone-based lubricant is an important aspect of routine maintenance
You can buy online: www.fitnessrepairparts.com
or www.gympart.com
sincerely.
E.CUADRA
MANAGUA,NICARAGUA
Nov 16, 2011 | Epic 425 Mx Treadmill EPTL88105 !
I need a service repair man for an EPIC 425MX treadmill. Please let me know of one Thanks
Dear Sir:
I can send to the web page for you contact service repair:
http://fitness.manualsonline.com + www.treadmilldoctor.com
since that i can not arrive, because I AM live in Managua, Nicaragua.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Aug 22, 2011 | Epic 425 Mx Treadmill EPTL88105 !
Epic Comfort step 425mx treadmill that we have is stuck on incline. How do I get it to go back down?
This happened to my treadmill. You need to get to the motor and see if the belt is fraying. If so, the fibers may have gotten entangled in the motor causing it to stay at the highest incline level. Once you clear this the treadmill will go up and down again. Hope this helps!
Dec 27, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Epic is sending me a replacement motor for my 425MX. Is it easy to change out the old one? Any secrets I need to know before starting?
You will need to loosen the rear roller off 8-10 turns on both sides to reinstall the motor drive belt...
Dec 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
Manual to trouble shoot/run diognostics
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 30, 2010 | Epic 425 Mx Treadmill EPTL88105 !
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
Epic 425 Mx Treadmill EPTL88105 ! Logo
101 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
