Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite model 596.76592600 ice maker does not make ice after changing water filter
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    ngfam1
    • 639 Answers
    SOURCE: ICE MAKER ON KENMORES ELITE SS
    Friend,
    ngfam1 At your service!
    You need service this time !
    Sounds like a Thermostat problem!
    How old is the ice maker?
    If is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
    You need a hands on tech for this repair!
    Below I referred you to a great service nation wide!
    If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
    A&E Factory Service
    A&E has schedulers available to take appointments 24/7
    And they do warranty work too, for most manufactures!
    1(800) 905-9505
    You will be fine
    Bless You ngafm1
    PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
    Posted on Aug 31, 2008
    • 62 Answers
    SOURCE: Kenmore Elite refrigerator 795.775.62600
    make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
    Posted on Sep 06, 2008
    huuum
    • 750 Answers
    SOURCE: kenmore elite, will not make ice, but it does dispeanse
    Dear tnsmarchini
    You said, Kenmore elite, ice maker in door...........................???What????????
    And we need more detail than Ice maker in door.
    What does your ice maker do?
    Posted on Sep 27, 2008
    Ice maker is not producing ice after changing water filter. Water is dispensing normally.
    It may take some time for the icemaker to get the water after a filter change or there could be other problems
    Mar 14, 2015 | Kenmore Elite 106.54619300 Refrigerator
    Water freezing in tube to icemaker
    Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
    Kenmore Model Numbers
    Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
    No water coming from water dispenser.
    It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
    Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker issues - what to do next?
    I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
    Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker not working but water is new filter elite 75542 40re1451
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    uittu
    Jun 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Moldy Ice from Ice Maker
    Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
    Jun 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
    69 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
